You are correct but apparently it is stated here instead:
http://www.minipeopl...3/rovermems.pdf
"When the ignition is switched on, a voltage
supply is made to MFU terminal 6/2, and the
ECM briefly earths MFU contact 6/1 at ECM
terminal 20. This energises the fuel pump
relay, and causes the fuel pump relay contacts
to close. Terminal 8/6 is thus connected to
terminal 8/4, and voltage is thereby output
to the fuel pump circuit. After approximately
one second, the ECM opens the circuit, and
the pump stops. This brief running of the
fuel pump allows pressure to build within
the fuel pressure lines, and provides for an
easier start. The fuel pump circuit will then
remain open until the engine is cranked
or run. Once the ECM receives a speed
signal from the CAS, the fuel pump winding
will again be energised by the ECM, and
the fuel pump will run until the engine is
stopped."
Edited by xrocketengineer, 03 June 2015 - 10:02 PM.
