Rear Window Louvre
Posted 18 May 2015 - 09:55 AM
I was just wondering drink if there are any benefits for having a rear window louvre?
I think they look great.
On the flip side, do they cause any problems?
Thanks in advance
Posted 18 May 2015 - 10:59 AM
They help keep the interior temperature down when parked or driven under hot sunshine.
Downside is that they do reduce rear vision somewhat.
Posted 18 May 2015 - 02:40 PM
Would they help visually when it rains? Since there's no wiper.
Posted 18 May 2015 - 04:24 PM
Unlikely as the rear window get wet & grubby from the spray rather than from the water falling vertically. It might reduce it a bit, but you won't know until you try it, or find someone who has.
Posted 18 May 2015 - 05:11 PM
Posted 22 May 2015 - 10:51 AM
Posted 25 May 2015 - 06:37 PM
I thought louvred rear window covers had to be quick & easy to remove for window cleaning. Be a bit of a b****r if they weren't.
Posted 25 May 2015 - 07:26 PM
A "Hedgehog" Gutter brush...... ![]()
Posted 26 May 2015 - 07:14 AM
Posted 27 May 2015 - 04:22 PM
I don't think it's a good idea to bond the louvred panel onto the car. Why not modify it so that it can be removed easily. Can't be a difficult thing to do.
Posted 06 June 2015 - 12:02 PM
These are easy to remove imho, but its not a matter of some easy clips, to do it safely you should remove the fillet strip.
New louvres can be modified, but its not easy to add a support in the center of.the louvre ( well its easy, but doesnt look that good)
They help to keep the window cleaner and I just sprayed with a cleaning sollution on the glass to clean it. It does help to keep the car cooler too, apart from getting lots of intrest at shows 3:)
