Front Lower Arm Problem
johnR
, May 18 2015 06:27 PM
Best Answer Spider , 18 May 2015 - 08:54 PM
As the other guys have said.
When I have to remove the insert from the pin, to avoid damaging the pin, I file a flat across the insert, tedious and takes a few minutes, but always gives a good result.
Go to the full post
4 replies to this topic
Posted 18 May 2015 - 06:27 PM
Whilst re-building my front subframe I have found that, bizarrely, my lower arm pin shafts are different diameters!
One will fit in the metal tubes inside standard bushes and one won't.
Does anyone know if it would be OK to remove the metal tubes from one set of bushes?
I notice that the nylon bushes don't have the metal tubes in them.
John
John
Posted 18 May 2015 - 06:31 PM
I would say you still have a tube on the fatter one. Get it off.
Posted 18 May 2015 - 06:39 PM
+1
Or get a new bottom arm pin.
Posted 18 May 2015 - 08:54 PM Best Answer
Posted 19 May 2015 - 07:19 AM
You're quite right it was old insets stuck on the pin!
Heat and a grinder removed them successfully, Many Thanks,
John
John
