Oil Pressure Light
19 replies to this topic
#16 Helter_skelter
Helter_skelter
  • 126 posts
Posted 10 June 2015 - 08:19 PM
Okay yeah fair enough I usually live by that too. Will check if my mechanic has one. If not ill get that one you linked. Will give you a shout if I get stuck think I have a fair idea how to do it.
#17 Fossy313
Fossy313
  • 583 posts
  • Local Club: Mini Club Jersey
Posted 12 June 2015 - 05:51 AM
if anything it will put your mind at ease,
good luck!
#18 Helter_skelter
Helter_skelter
  • 126 posts
Posted 22 June 2016 - 07:31 PM
Mega bump. But i did end up getting the pressure and if i recall it was at about 20psi or just bellow when warm? It is all fresh oil and filters there was no metalic shimmer etc in the oil. Thinking on replacing the relief valve as suggested or at this psi i that a not going to be the case?
#19 Helter_skelter
Helter_skelter
  • 126 posts
Posted 27 June 2016 - 07:29 AM
if i was to replace the reliefe valve would this be the correct part along with the copper washer linked in the description? http://minispares.co...|Back to search
Also i notice it mentions grinding the plunger? I am a little unsure of this bit and the haynes mentions nothing about it, could someone shed some light on this? maybe any other tips for removal and fitting?
also is it a waste of time replacing this part or could this be what is causing the issue with my pressure?
#20 ryomini
ryomini
  • 583 posts
Posted 29 June 2016 - 04:21 AM
Nice thread
plus one to all the sensible comments
amazing that such an important issue in cars is only covered by this little switch and light
keith calver shows a mod for the pressure 'bullet' and spring
(I am not sure if my mod was the best but I cut the 'bullet' in half, less area to get stuck, but still holds the spring and then just filled it with holes)
photobucket is down so I can't post the link right now :{
