speaker size
17 replies to this topic
#1 wilcooper
wilcooper
  • 1,197 posts
Posted 26 July 2006 - 12:59 PM
ok, im confused now, im after some circular speakers but i dont know if im after the 5.25"/13cm size or the next size up, 6"....
the parcel shelf has holes already cut out for speakers....the holes have a diameter of 13cm, but then if you include the mounting holes into the diameter, it comes to 6"
ive drawn a basic diagram to show what it is like...theres the hole 13cm, then the mounting holes ring (grey) at 6" then the outer ring could be the cover over the top?
diagram if img doesnt work
cheers for any help.
#2 jif2006
jif2006
  • 622 posts
Posted 26 July 2006 - 01:16 PM
13cm spakers dude
#3 wilcooper
wilcooper
  • 1,197 posts
Posted 26 July 2006 - 01:45 PM
vibe slick 50
i was looking at these, but they say mounting diameter 100mm?? whats this mean?? :S
the head unit im looking at is...
alpine cd
could recommend any speakers?
#4 wilcooper
wilcooper
  • 1,197 posts
Posted 26 July 2006 - 02:48 PM
bump need advice :geek:
#5 wilcooper
wilcooper
  • 1,197 posts
Posted 26 July 2006 - 03:32 PM
ummm, comp or coax?? :S
#6 StaffordSi
StaffordSi
  • 125 posts
Posted 26 July 2006 - 03:45 PM
100mm = 10cm, so there too small...... and the head unit looks fine
#7 wilcooper
wilcooper
  • 1,197 posts
Posted 26 July 2006 - 04:30 PM
so can anyone recommend any 13cm speakers to go with the alpine head unit which will sound good?
my mini is fairly loud too :geek:
price range about £40
#8 PhoenixSimon
PhoenixSimon
  • 1,050 posts
  • Local Club: BOGMOC
Posted 14 August 2006 - 02:18 PM
alpine head unit is good, you cant beat alpine for sound quality, no stupid flashy gymics that break just good quality, as for speakers JBl have just released there new range and do a GTO-527 which would be ideal, probably whats going in my car.
Simon
#9 tomtic
tomtic
  • 177 posts
  • Local Club: None
Posted 12 October 2006 - 07:28 PM
http://www.caraudiod...roducts_id=5122
Are these the ones you were talking about? £30, that seems very cheap for speakers, are they any good?
Also what are all the options for mounting 13cm speakers?
Edited by tomtic, 12 October 2006 - 07:28 PM.
#10 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 12 October 2006 - 08:18 PM
same as any other, you could box it in.. but you'll need to find out the size of box needed to get a brill sound outta them... or it will sound arse..., or you can mess with angles etc. Subs can pretty much point anywhere as the low low frequencies aren't directional as such... rathermore the sound is pushed from all angles away form the sub like a forcefield,... Get them comps pointing at your ears... and 6.5" will sound beautiful as they give a njice punch to them too.
I found that 6.5" when compared to 6" comps supported the Mid range of frenquencies much bettem gave the music much more punch and belly.
lol said it so much before but... you get what youi pay for, buy the best you can possibly afford.
#11 tony_yates
tony_yates
    Starting My Mini Up
  • 3 posts
Posted 29 November 2006 - 04:41 PM
Hi,
My wife has a 1993 Cooper and I'm buying a new cd and speakers. But as it's a surprise I don't want to dismantle the current speakers as it'll give the game away. I sort of measured the underside of the speakers from the boot and it seemed to be 13cm but couldn't be sure, hence my question:
Is 13cm pretty standard?
Regards,
Tony
#12 Ollie
Ollie
  • 278 posts
  • Local Club: TurboMinis
Posted 29 November 2006 - 06:09 PM
i brought some which i thought would go straight in without having to cut a bigger hole....but got them and i did :w00t:
but i just cut slots every couple of cm and bent it down... went in fine :o
#13 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 29 November 2006 - 07:32 PM
the ones i took out of my mini were 16cm
#14 edjohnson
edjohnson
  • 291 posts
Posted 29 November 2006 - 08:30 PM
the JBL gto speakers are very good for the money, my mates got them in his 106, i had them in the golf, 306, metro, AX, and the polo, and my mates got em in his scooby too. so i like em
They seem to put out decent defined bass, rather than loud low down mess.
coupled with a sub and some decent speakers up front you will have a very good balanced system
#15 miniboo
miniboo
  • 9,327 posts
Posted 29 November 2006 - 10:11 PM
no point having speakers on the back shelf if you have a sub in the boot.
