Headlining/roof Lining Replacement.
Posted 07 June 2015 - 07:29 PM
I have a slight dent in my roof, hardly enough to notice but I know it's there.
I'm thinking if I have the headlining out I can (I think) work the dent out.
Is replacing the headlining a big job, tricky job?
Any advice gratefully received. Thanks.
Posted 07 June 2015 - 07:38 PM
It can be a tricky job, but if you're patient it'll also be a good job. All I can say, from doing mine, is don't rush it, whatever you do. There's nothing worse than creases . . .
Posted 07 June 2015 - 07:51 PM
Posted 08 June 2015 - 12:07 PM
I think the easiest to use is the 'aerosol' type glue. Out here in South Africa it's not so easy to come across that kind of product. I just used a simple brush on glue, but was careful to only put it in sections that will be covered by the rubber seals - that way you avoided any kind of stains.
