Rivnut Tools
24 replies to this topic
#1 fenghuang
fenghuang
  • 796 posts
Posted 11 June 2015 - 12:40 PM
Rivnut tools (not the airtool type):
Type.
Ease of use.
Brand.
Price.
Quality.
Discuss.
#2 coopdog
coopdog
  • 4,506 posts
Posted 11 June 2015 - 12:43 PM
Ebay
#3 adam_93rio
adam_93rio
  • 3,271 posts
Posted 11 June 2015 - 12:44 PM
From my experience, the air ones are the only ones that last.
No matter what make or type I've had something has gone wrong with it, I tend to go for a mid range price wise, but if it's something you're doing all the time then the ones that look like a rivet gun are the best, unless you've got £500 kicking about to pay for a decent air one
Don't bother with the cheap slider ones, they're a swine to use compared with the rivet gun style ones
#4 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 11 June 2015 - 12:50 PM
I bought my plier type from a guy over there a few years back, his site was Mr Rivnut or something like that it came with 3mm to 6mm mandrels and a selection of stainless rivnuts. I got it from the UK because I couldn't find stainless metric rivuts over here. It works fine I wouldn't want to put a lot of rivnuts in with it but it works fine for the 20 odd 5mm that I've put in my car.
Edited by bikewiz, 11 June 2015 - 01:04 PM.
#5 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 11 June 2015 - 01:20 PM
I have the rivnut tool listed on e-bay under item number 290956647705 It is good quality and also does rivstuds and pop rivets. Spare mandrel so are available if need be. It's certainly good enough for home use
#6 Spider
  • 15,201 posts
Posted 11 June 2015 - 08:52 PM
I bought this kit a few years back;-
http://au.rs-online....oducts/6235549/
Has M3 to M6 in the Kit, Mandrels, Rivnets and Hand Clincher. There is also an option M8 Mandrel available for it. Spares are also available.
I thought it great value at the time and now I wonder how I ever got by without it.
My only 'problem' with all Rivnut type tools and Nuts available these days it it seems that only Metric is available. None the less, I have on occasion tapped out some of these after fitting to UNF sizes without problem.
#7 fenghuang
fenghuang
  • 796 posts
Posted 12 June 2015 - 09:19 AM
... the ones that look like a rivet gun are the best ... Don't bother with the cheap slider ones, ...
Can you link to a pic of either type as I'm not sure which ones you're refering to.
http://au.rs-online....oducts/6235549/.
Can't get the link to work and searching the site for Rivnut tool doesn't return any results.
#8 Spider
  • 15,201 posts
Posted 12 June 2015 - 09:44 AM
Maybe try this link
http://uk.rs-online....2332D3535343926
#9 R.S.P
R.S.P
  • 501 posts
Posted 12 June 2015 - 12:18 PM
I use this one works a treat http://www.ebay.co.u...=item439bcca0a4
#10 adam_93rio
adam_93rio
  • 3,271 posts
Posted 12 June 2015 - 09:17 PM
Worst type
http://www.ebay.co.uk/itm/380904779400
Better type
http://www.ebay.co.uk/itm/381097501021
Big daddy one
http://www.ebay.com/itm/171813592637
#11 ibrooks
ibrooks
  • 1,017 posts
Posted 18 June 2015 - 12:14 PM
I've got the middle type of those three but a somewhat better quality one - the parts of the tool are cast rather than pressed and folded steel. It's branded King-Klick and came in a set with a bunch of different size and types of rivnuts. I must have put hundreds of the things in with it over the years.
Iain
#12 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 19 June 2015 - 08:08 AM
I have this kit:
http://www.demon-twe...eting-kit-ak396
It's great. The head swivels on the body so good for tight spaces. I actually got mine from Demon Tweeks too. It was on sale for 40 quid one day when I was in there.
#13 fenghuang
fenghuang
  • 796 posts
Posted 20 June 2015 - 08:03 AM
Sorted now. Thanks for the input.
#14 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 20 June 2015 - 08:33 AM
The Matt I've got a cheap version of that and keep snapping the threaded insertion tool ( the bit that goes inside the rivnut when you put it in) what am I doing wrong?
#15 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 21 June 2015 - 07:57 AM
You do need to adjust the barrel properly so you're not over-compressing the rivnut. I guess if it's cheap metal with low tensile strength then the threaded part of the tool will snap as you pull it up. Mine has done hundreds of fittings now and never had an issue.
