Rivnut Tools
#16
Posted 21 June 2015 - 09:54 AM
#17
Posted 21 June 2015 - 02:43 PM
... With the bigger ones or ones you wont need very often, you don't need the pliers, just a nut, bolt and washer to fit them.
Do you mean it's worth using a washer between the rivnut and the panel it's fitted to, or just for the bolt you fit to it? If it's for the rivnut, which side of the panel?
#18
Posted 21 June 2015 - 02:55 PM
Do you mean it's worth using a washer between the rivnut and the panel it's fitted to, or just for the bolt you fit to it? If it's for the rivnut, which side of the panel?... With the bigger ones or ones you wont need very often, you don't need the pliers, just a nut, bolt and washer to fit them.
Nope the washer is when you are not using the tool. So the nut has something to press on while not trying to turn the rivenut.
#19
Posted 21 June 2015 - 04:00 PM
Ah. So you put a washer onto the trhreaded part of the tool before threading on the rivnut itself, right?
#20
Posted 21 June 2015 - 04:14 PM
This is with no tool.
Edited by nicklouse, 21 June 2015 - 04:16 PM.
#21
Posted 21 June 2015 - 04:16 PM
Ah. Gotcha!
#22
Posted 23 June 2015 - 12:38 AM
First you need bolt approximately 2" long with full thread, a nut to suit and a flat washer. A bit of lube for threads.
Screw the nut all the way onto bolt, then washer, then rivnut insert with the flange end towards washer. Put on till theres bolt thread protruding a bit out end.
Then put it into hole drilled to correct size.
Using two spanners, one holding bolt from turning, tighten the nut down to compress the insert till it feels firm in hole.
Release nut and unscrew bolt out of insert.
As i mentioned, you don't need to fully compress it, this will happen when you tighten the attachment on.
It's important to have some sort of lube/rust proofing on bolts as if the bolt(s) seize in insert its a bugger to get undone, especially On blind panels.
Sorry if I over simplified it for some.
#23
Posted 23 June 2015 - 10:14 AM
It's also worth making sure it's a decent grade of bolt - socket caps will almost always be 10.9 at least so they are a good bet.
There's a lot of 4.8 rubbish coming out of the far east nowadays - there was a time when you had to hunt to find bolts that soft if you needed them for something.
#24
Posted 23 June 2015 - 11:04 AM
I use this one works a treat http://www.ebay.co.u...=item439bcca0a4
I have this one nice peice of kit and use it quite alot
