Knocking From Engine/behind Steering Wheel
Best Answer New game mini , 09 August 2015 - 08:10 PM
For anyone reading in the future the noise waaaassss.........THE SPEEDO CABLE!! Speedo started dancing around today so I unhooked the cable and no noise! Hallelujha!! Just gotta fit a new one now which i believe is a bugger 😱😱
Thanks for all the help. Go to the full post
16 replies to this topic
#1 New game mini
New game mini
  • 294 posts
Posted 04 July 2015 - 05:01 PM
Hi all. I've got a knocking/clacking noise just start up in my 86 Mayfair that sounds like its coming from behind the steering column/in the engine bay after an hours drive today. Its only there when the car is moving (not idling) and increases and decreases in speed in time with the car. It went through a period of doing it a few months back but stopped of its own accord??? Noise doesn't change with braking/cornering/over bumps Any ideas what this could be as im clueless? :D
Jamie
Edited by New game mini, 04 August 2015 - 06:15 PM.
#2 antcole
antcole
  • 307 posts
Posted 04 July 2015 - 05:12 PM
Check the top engine steady between the cylinder head and the bulkhead just under the clutch master cylinder.
Physically grab the engine (when its cooled down and off), and give it a shove. If it moves a lot, the bushes in the steady are goosed.
Easy to change and cheap.
#3 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 04 July 2015 - 05:39 PM
Does it get more rapid as the refs go up? Or does it happen on acceleration and decceleration?
#4 New game mini
New game mini
  • 294 posts
Posted 04 July 2015 - 07:24 PM
It happens on acceleration, cruising and deceleration but not while the car is stationary and revving. The noise sounds like putting a piece of paper in a spinning fan if that makes sense!!
#5 Batmini
Batmini
  • 378 posts
Posted 04 July 2015 - 07:28 PM
Pot joint or pot joint gator clip ?
#6 New game mini
New game mini
  • 294 posts
Posted 04 July 2015 - 07:29 PM
Thanks. Tried this but seems pretty tight, only very minimal movement.
#7 New game mini
New game mini
  • 294 posts
Posted 04 July 2015 - 07:32 PM
Whats this? :-) sorry my knowledge is very limited
#8 Batmini
Batmini
  • 378 posts
Posted 04 July 2015 - 11:02 PM
Look underneath the car, follow the drive shaft from the wheel, big joint just before it goes into the gearbox. Also, if they're still fitted, check you dont have anything stuck in between the brake disk an it's dust cover.
#9 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 04 July 2015 - 11:10 PM
You said it...fan to shroud
#10 New game mini
New game mini
  • 294 posts
Posted 05 July 2015 - 09:54 AM
Awesome thanks! :-)
#11 New game mini
New game mini
  • 294 posts
Posted 27 July 2015 - 03:16 PM
Hi folks, still cannot locate the source of this knocking sound!! I've attempted to record the sound but apologies for the very shaky video. Anyone have any ideas?
https://youtu.be/S6FiV3kWjyw
#12 New game mini
New game mini
  • 294 posts
Posted 27 July 2015 - 08:07 PM
Cheeky bump 😃. My main worry is that its something suspension/steering wise and that something is suddenly going to go bang whilst driving.
#13 New game mini
New game mini
  • 294 posts
Posted 04 August 2015 - 06:24 PM
Still not managed to sort 😞 i've checked:
*Engine steadies
*Exhaust
*Crap behind dust covers on brakes
*Pretty sure it's not fan to shroud (noise in the wrong area)
Looks like its a trip to the garage 😞
My mate said it could be something in the speedo, does that sound plausible?
#14 mini stephen
mini stephen
  • 138 posts
  • Local Club: unkown
Posted 04 August 2015 - 06:39 PM
Wow wish I could help that sounds expensive but to solid a noise for the speedo to me
#15 New game mini
New game mini
  • 294 posts
Posted 09 August 2015 - 08:10 PM   Best Answer
