Edited by danny19boy86, 06 July 2015 - 12:27 PM.
Carb Backfire
Posted 06 July 2015 - 12:25 PM
Posted 06 July 2015 - 12:31 PM
There are two main possibilities for carb backfires. The first is timing. Did you set the static timing when you put the engine in and if so what timing figure did you use? The second source for carb backfires is an extremely lean mixture. Was the carb set up before you put it on the 1380 or was it taken apart and overhauled so the carb settings may be "off"?
Beyond those two main sources of the backfire you could have loose manifolds allowing air to leak in and lean the mixture. When fitting the distributor you may have put the plug wires on in the wrong orientation.
Posted 06 July 2015 - 01:03 PM
Posted 06 July 2015 - 01:05 PM
You say it was running in another car, was it running with the carb fitted or is it one you have fitted??
Posted 06 July 2015 - 01:07 PM
Posted 06 July 2015 - 02:09 PM
Sounds like a carb issue then. That will need setting up and of course the correct needle to suit.
Posted 06 July 2015 - 04:15 PM
And... did you remove the distributor, install the engine, then reinstall the distributor or did you leave the distributor installed while installing the engine.
Posted 06 July 2015 - 04:17 PM
It was running in another car but with a Webber carb
Is this the same Weber carb it was running on before or another Weber carb?
Posted 06 July 2015 - 04:29 PM
It's a Hif 44
Posted 06 July 2015 - 05:01 PM
there was no distributor withe the engine. So I used mine of my 998. I guess I shouldn't haveAnd... did you remove the distributor, install the engine, then reinstall the distributor or did you leave the distributor installed while installing the engine.
Posted 06 July 2015 - 05:18 PM
The engine should be able to start and run with any Lucas distributor that fits. However, the advance curve may not be right for driving the car. It doesn't sound like you have the engine running enough to have driven it at all yet to know.
If all you did was install the distributor and you did not set the static timing, the engine is not likely to start. Are you familiar with carrying out static timing? Does this distributor have electronic ignition or points?
Posted 06 July 2015 - 06:01 PM
Posted 06 July 2015 - 06:06 PM
Are your plug leads on in the correct order?
Posted 06 July 2015 - 06:11 PM
It's a Hif 44
My bad, didn't see that vital nugget.
Danny, how did you set up the distributor? Or did someone set it up for you?
Posted 06 July 2015 - 06:22 PM
It's a Hif 44
Is this the same Weber carb it was running on before or another Weber carb?It was running in another car but with a Webber carb
1243 clockwise on distributor and 4321 on head
