Carb Backfire
16 replies to this topic
#16 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 06 July 2015 - 07:58 PM
I've had a few too many sherbets to do the mental gymnastics, is it the same as this? : http://www.theminifo...ttach_id=160243
#17 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 06 July 2015 - 08:17 PM
Since the static timing has not been set yet, please visit my online storage space in the link below.  Look for and download a copy of the PDF that discusses static timing.  For general information you may also want to download the PDF that discusses Lucas points ignition systems.
https://www.sites.go...wson/home/files
As a footnote to the timing and firing order discussion, the distributor in the A-series engine has a shaft that rotates COUNTERCLOCKWISE when you are standing at the front of the car and looking at the engine.  The firing order is 1-3-4-2 counterclockwise.  This is discussed at some length in the PDFs I suggested you download.
The image below is often shown on threads on this board.  It is a good guide for which cylinder is which and the direction of distributor shaft rotation.  If the drive gear for the distributor is in the "correct" position in the block, it is also a good reference for where the sparkplug wires should connect to the dizzy cap.
2012-04-14_201159_73_mg_midjet_firing_or
