Static Timing Curve
14 replies to this topic
#1 darkcat
darkcat
  • 398 posts
Posted 07 July 2015 - 09:06 AM
Morning all
I'm just trying to set up the ignition timing on a 1380, and need to get a baseline static timing curve.
In the form:
Idle (1000rpm) - 8 deg BTDC
max advance at? and how much?
or a graph... any format really!!
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 07 July 2015 - 09:18 AM
Faqs curves for the Aldon yellow and Red, max advance used to be 34degs but depending on CR and fuel could be as low as 28degs
#3 Spider
  • 15,107 posts
Posted 07 July 2015 - 10:02 AM
Hmmm sorry, maybe I'm being picky (and should shut up?) but static is stationary and to get a curve it has to move (or spin). Sorry, I don't mean to be-little at all, just get the terminology squared away!
Ideally, to sort what characteristics - curve - the dissy should have to suit your engine, it really needs a dyno session as the engine is no longer standard, so we can look it up in a book.
You could do as KC (above) suggest, it will work OK, but you may not get the best possible from your 1380.
#4 jaydee
jaydee
  • 8,565 posts
Posted 07 July 2015 - 10:17 AM
I think he means the baseline curve with no vacuum advance
That is (in a standard non leccy dizzy) called mechanical advance curve
by the way Static timing is a different thing, and by static timing you usually refer to a way of setting timing
#5 Spider
  • 15,107 posts
Posted 07 July 2015 - 10:32 AM
It maybe helpful to also read this FAQ
http://www.theminifo...d-distributors/
#6 darkcat
darkcat
  • 398 posts
Posted 07 July 2015 - 10:58 AM
Yes what im after is the baseline timing with no vac.
Sorry to the terminology police!
#7 carbon
carbon
  • 2,590 posts
Posted 07 July 2015 - 06:07 PM
Need a lot more info before even making the wildest guess:
- CR
- cam
- other modifications
- fuel octane
As Kernow Cooper says the total advance for normally aspirated could be anywhere between 28 and 34 degrees, depending on cam, CR, and fuel octane.
#8 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 08 July 2015 - 12:47 AM
I've got a "dial back" timing light which means you only need the TDC line on the flywheel.
If you want 30 degrees advance at 4000 rpm you set the timing light to 30 degrees and hold the engine at 4000rpm and then line up the timing marks.
You could also use this to hold the engine at various revs (1000, 2000, 3000, 4000) and record the advance to work out the mechanical advance curve. Normally it's all advanced by 4000rpm.
Alternatively you can buy a Accuspark Blackbox and disable the mechanical advance, and have it all programmed by the unit.
http://www.accuspark...uk/Blackbox.htm
There is an Aussie thread on them here
http://www.ausmini.c...php?f=2&t=83483
Edited by timmy850, 08 July 2015 - 12:58 AM.
#9 darkcat
darkcat
  • 398 posts
Posted 08 July 2015 - 07:50 AM
Timmy, I'm going to have to assume you didnt read or understand the question, I am already running programmable ignition, and am looking for a baseline curve to program into it.
As for spec:
1380, ported standard head, kent 276 cam, CR assumed approx 10:1,
#10 Spider
  • 15,107 posts
Posted 08 July 2015 - 08:23 AM
As for spec:
Sorry mate, but in all fairness, I don't think any of us knew that.
In that case, here's a post from Dave in FAQ on the Aldons. I'd suggest (as Dave did in another way) kicking off with something along the lines of the Yellow.
#11 darkcat
darkcat
  • 398 posts
Posted 08 July 2015 - 08:27 AM
True, i didnt actually mention that, probably should have, but still a vague curve is all im after :-)
#12 Spider
  • 15,107 posts
Posted 08 July 2015 - 08:41 AM
Bhahaha,,,, sorry, I forgot the link in my last - DOH!!
http://www.theminifo...advance-curves/
#13 Ethel
  • 26,060 posts
Posted 08 July 2015 - 09:07 AM
See if you can google up some megajolt maps.
#14 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,859 posts
  • Local Club: man Estate
Posted 08 July 2015 - 02:16 PM
A mighty fine read there Timmy, almost all way over my head mind :D
#15 carbon
carbon
  • 2,590 posts
Posted 08 July 2015 - 04:37 PM
As for spec:
Fuel octane?
Would be wary about assuming CR, and have you run a compression test?
