Permanent Live On The Fuse Box
14 replies to this topic
#1 Minitrio
Minitrio
  • 420 posts
Posted 21 July 2015 - 09:30 AM
Hi All,
Just a quick one, need a permanent live off the Fuse box on my '89 998.
Can anyone point me to which one or anywhere else I can safely wire one in?
Thanks in advance
#2 Spider
  • 15,201 posts
Posted 21 July 2015 - 09:37 AM
There should be a terminal with Purple Wires to it, That is a fused permanent live.
Edited by Moke Spider, 21 July 2015 - 08:44 PM.
#3 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 21 July 2015 - 09:46 AM
locations 3-4 I believe
http://www.theminifo...s-covered-data/
#4 CityEPete
CityEPete
  • 3,920 posts
Posted 21 July 2015 - 09:51 AM
The Brown on terminal 3 is the unfused feed coming in from the starter solenoid where all the permanent lives join, it depends what you are doing with it as to what you do next?
#5 Minitrio
Minitrio
  • 420 posts
Posted 21 July 2015 - 11:42 AM
Cheers guys, I intend to run a second 6 fuse box inside under the lower dash rail, to run the modern stereo, clock and USB Charger point. Was thinking of running additional gauges off it, but they don't require a permanent live.
#6 CityEPete
CityEPete
  • 3,920 posts
Posted 21 July 2015 - 12:03 PM
You could actually run another cable neatly from the solenoid then and make sure you use a gromitt where it comes through the bulkhead, that would save adding extra load to the existing fuse box feed cable and you could even put an inline fuse in the engine bay to isolate the new fuse box too.
#7 Minitrio
Minitrio
  • 420 posts
Posted 21 July 2015 - 12:09 PM
Now that sounds a good idea, not sure what amp inline fuse to use thou....
#8 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 21 July 2015 - 12:21 PM
Depends on the stereo really...from what you have listed 15 amp should cover it
#9 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 21 July 2015 - 12:24 PM
by the way I have done something similar before and I mounted the additional fuse box on a hinged panel that flapped down for viewing and access
#10 CityEPete
CityEPete
  • 3,920 posts
Posted 21 July 2015 - 01:57 PM
Sounds like it's coming together nicely now then.
#11 Minitrio
Minitrio
  • 420 posts
Posted 22 July 2015 - 11:55 AM
There is a 20amp in the back of the stereo, so a 15amp down the line would suffice.
Now time to install it all
Thanks for all your help guts
#12 Minitrio
Minitrio
  • 420 posts
Posted 22 July 2015 - 11:57 AM
Lol guys not guts. Predictive keyboards
#13 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 22 July 2015 - 12:08 PM
If you want a plug and play kit then give me a shout, we produce this exact kit built to your spec with all the correct gauge wiring etc.
Www.wiredbywilson.co.uk.
#14 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 22 July 2015 - 12:09 PM
#15 Minitrio
Minitrio
  • 420 posts
Posted 22 July 2015 - 10:47 PM
Cheers wiredbywilson, I already have all the parts to carry out the job, just need to join it all together.
I have booked marked your site for future reference
