Cam Timing Mg Metro Cam On 998
21 replies to this topic
#16 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 25 July 2015 - 08:29 PM
9.75:1 is perfect with 95Ron fuel and that cam.
AC
#17 Mini and Puck
Mini and Puck
  • 16 posts
Posted 26 July 2015 - 10:07 AM
Sorry, the 3cc is the volume of the block at tdc. Flat top pistons.
#18 Mini and Puck
Mini and Puck
  • 16 posts
Posted 01 August 2015 - 04:57 PM
Well, if anyone is still reading this saga....I have tried to get the cam timing set to 108. So I fitted a 4 degree, and got 105. I fitted a 3 degree and got 106. I fitted a 2 degree and got 109.5!!!! I mean what the ????? So I repeated the three degree and two degree woodruff key setup. Got the same readings. Has anyone heard of woodruff keys not giving the correct offset? I guess a two degree is incredibly small.... Of course a vernier timing gear would solve this,Mobutu that is an incredibly expensive option. My question is this. Am I better to go with the two degree at 109 ish, of the three degree at 106? I mean, 106 seems a bit much for a MG metro cam on a 998, even accepting that I am fitting a 12G295 head.
#19 Cooperman
  • 23,326 posts
Posted 01 August 2015 - 06:38 PM
109 degrees ATDC will be fine.
#20 Spider
  • 15,143 posts
Posted 01 August 2015 - 08:51 PM
I have had a few where almost at every turn you get a different result - cheap sprockets and chains will do that.
I'd suggest running with the 3 degree key (giving 1060).
#21 Cooperman
  • 23,326 posts
Posted 01 August 2015 - 10:13 PM
I take 3 readings at each setting and average them. I also get slightly different readings each time.
it'll run fine at an initial of 109 or 106, especially after the chain has stretched a bit.
#22 Mini and Puck
Mini and Puck
  • 16 posts
Posted 02 August 2015 - 06:48 AM
Right then! 106, with the 3 degree key it is!
