Ecu Choices
16 replies to this topic
#1 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 23 July 2015 - 08:03 PM
I'm building a bit of a track car at the moment and I'm blown away by the choice of aftermarket ECUs out there. Total minefield.
I'm going to be running NA, injection. I did run the CANEMS setup on my Mini and was actually highly impressed, but what are other people using?
One of my mates is trying to push me into MS3 Pro, but I'm concerned about a potential lack of support. I've been looking at MBE, second hand DTAs, etc. Just a bit lost.
Anyone got any suggestions? Budget is wide open as I'm in no rush and will be saving up/selling body parts to fund it.
I'd like to know what issues people have had, what response people have had from tuners, any issues with mapping software etc.
#2 turbonutter
turbonutter
  • 29 posts
Posted 23 July 2015 - 09:03 PM
Hiya mate have a look at the emerald ecu k6 Really good
#3 Midas Mk1
Midas Mk1
  • 5,793 posts
  • Local Club: S.U.N.M.C
Posted 23 July 2015 - 10:18 PM
sc typhoon?
#4 stoneface
stoneface
  • 400 posts
Posted 24 July 2015 - 07:43 AM
I have an emerald. Works very well, and Emerald in Thetford were very helpful and did a great job on the rolling road.
Whatever you choose, check out where you can get it mapped. Also get a system where you can get the software and modify/program it yourself.
Steer clear of Weber.
#5 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 24 July 2015 - 03:25 PM
spent ages looking round and went for adaptronic. great bit of kit plus you've got chris just up the road to set it up for you.
http://www.efi-parts...p?categoryID=88
what car/engine?
Edited by ANON, 24 July 2015 - 03:26 PM.
#6 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 24 July 2015 - 04:32 PM
MK1 Astra, Redtop with Jenvey tapered bodies. Not decided on bottom end or cam spec yet. But nothing massively lairy.
#7 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 24 July 2015 - 05:04 PM
go for the adaptronic ;-)
i might even be able to get one for a slightly better price if you wanted one.
#8 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 26 July 2015 - 06:40 AM
OK, Adaptronic looks like a good option. Seems to cover everything I'd need.
The other question is, do I look at second hand ECU options? It's not being used to compete in motorsport so I can "take the risk" a little with a second hand one. My main requirements are:
Mappable by myself
Tuners willing to map it (I struggled with MJ)
Wideband compatible
9000rpm limit (just in case I upgrade crank)
3D mapping
So really, most aftermarket ECU option cover my bases. Thanks for the input so far.
#9 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 26 July 2015 - 04:53 PM
you never seem to save much when you go used plus if you get something with a loom you're taking a chance that whoever built it up has done a decent job of it in the first place.
how come you want wideband?
#10 stoneface
stoneface
  • 400 posts
Posted 26 July 2015 - 05:11 PM
I use a wideband with my emerald. It allows for adaptive mapping and accurate AFR monitoring.
I assume it's the same for other makes of ecu.
#11 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 26 July 2015 - 05:43 PM
I mainly want wideband so I can monitor AFR on a gauge. That's all. I can do that with a separate sensor/controller/gauge, but wanted it to be an ECU function if possible.
#12 stoneface
stoneface
  • 400 posts
Posted 26 July 2015 - 06:05 PM
I know with the Emerald you need an extra controller to add a wideband lambda. I use a Techedge controller but others like innovate or PLX are also available.
I don't know if the Adaptronic needs and extra controller.
#13 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 26 July 2015 - 06:52 PM
I had a Techedge 2J2 on the Mini (running CANEMS ECU and 45mm Jenveys). Seemed to work just fine and as I'd mapped it myself I liked to keep an eye on the AFR.
#14 stoneface
stoneface
  • 400 posts
Posted 26 July 2015 - 07:15 PM
Techedge 2J2, thats what I use with Emerald ECU and weber 40mm bodies. I looked at quite a few different ECU's before going with Emerald and most did what I wanted. In my case it just came down to the comunication and help I had when called round the manufacturers. Customer service goes a long way.
#15 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 26 July 2015 - 07:23 PM
I guess the next step is talk to a tuner who's good with Redtops (and fairly local) to see what their preferences are.
No point buying an ECU that nobody local will map. I guess as the Redtops are such a commonly tuned engine, most tuners will be happy to deal with them...or I hope so anyway!
