Help With A Location For Hs4 Carb Hose
Best Answer Stiggytoo , 25 July 2015 - 06:12 PM
Sorry I was thinking of an hif carb for some reason. That's your fuel overflow which ideally should be routed away from anything hot. As I've said, it would originally go to a metal section of pipe which traces along the top and towards the front of the clutch 'wok' to the ground.
Go to the full post
Posted 25 July 2015 - 02:49 PM
It's a 1989 998 Austin mini running all standard gear
Thanks for any replies and sorry if it's already posted but I read around and couldn't understand/find what I was looking for
Posted 25 July 2015 - 03:23 PM
I believe there are 4 hose connections on you carb. The fuel pipe is easily identifiable. The small one above (ish) that one is the fuel overflow which usually goes to a metal pipe along the clutch cover (or wok) to the ground. The larger diameter outlet left over is a breather which should be connected to the engine breather canister.
The tiny outlet is for the vacuum advance.
Edited by Stiggytoo, 25 July 2015 - 03:23 PM.
Posted 25 July 2015 - 03:25 PM
The fuel inlet goes to the float valve which is under junction of the Tee (see also the bulge in the casting by the screw). Any of the branches of the Tee can be used, sometimes 2 have pipes if the carb is one of a pair. The float vent is in the centre of the lid, so the pipe will point towards the centre and be the lower one if there's a fuel inlet above. If you were looking at a larger pipe near the throttle, that's for the crank case breather.
Posted 25 July 2015 - 03:34 PM
Edited by da2428, 25 July 2015 - 03:34 PM.
Posted 25 July 2015 - 06:12 PM Best Answer
Edited by Stiggytoo, 25 July 2015 - 06:13 PM.
Posted 25 July 2015 - 06:31 PM
okay, i suspected as much but thought id check as its a fuel system and the pipe was sitting near my exhaust , cheers for the info
Posted 25 July 2015 - 07:36 PM
