Boost Leaks
Posted 25 July 2015 - 03:22 PM
Posted 25 July 2015 - 03:28 PM
Where's your boost gauge plumbed in?
Posted 25 July 2015 - 03:39 PM
Posted 25 July 2015 - 04:13 PM
Well the carb wouldn't work if there was no depression across it.
Posted 25 July 2015 - 04:34 PM
Posted 25 July 2015 - 09:39 PM
Phil.
Posted 25 July 2015 - 09:45 PM
Posted 25 July 2015 - 10:23 PM
The gauge is in the right place to tell you what's actually going in to the engine, which is what you're interested in, if you want to avoid detonation. The carb needs lower pressure (a depression) above the fuel jet than above the fuel in the float chamber to push the fuel through. The carb has to reduce the pressure in the venturi a bit to achieve that.
Phil makes a great point about intercoolers - the reduced pressure is actually a good thing, you want more oxygen molecules (for combining with fuel molecules) to make power. Cooling the air makes it more dense - same mass taking up less volume = lower pressure. Vapourising fuel will also have a cooling effect that wasn't as prevalent in the suck through system.
The gauge is showing evidence of the improvement you've made, that's all.
Posted 25 July 2015 - 10:26 PM
Posted 28 July 2015 - 05:52 PM
Posted 28 July 2015 - 06:00 PM
