Car Jerking Badly
20 replies to this topic
#16 Cooperman
  • 23,569 posts
Posted 28 July 2015 - 03:27 PM
I have also had problems with 'Lucas' coils, even the so-called 'Sports Coil'.
In the end I went to a motor factor and bought a Delco coil and that has been fine for a long time now.
Peter Baldwin said that the 'Pertronix' coils from the USA are the best, but they are expensive.
#17 bob540
bob540
  • 357 posts
Posted 28 July 2015 - 05:36 PM
You were all right of course! Had a look just now and one of the wires coming from the coil is broken:
Had quite a bit of engine movement not too long ago from a knackered engine steady bush so I'd say that may have stressed the connection.
There's no wire left coming out of the connector (not sure what it's called, picture below) so I don't think I'll be able to reconnect it to the wire. I assume they're common and I'll be able to get a replacement in my local motor factors?
#18 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 28 July 2015 - 07:00 PM
You can buy terminals such as yours, however you are probably better off getting yourself a selection of insulated terminals, crimpers and wire strippers for other future jobs. You'll need a female spade terminal for your coil wire. (Like the one in the image below)
Edited by Stiggytoo, 28 July 2015 - 07:00 PM.
#19 bob540
bob540
  • 357 posts
Posted 28 July 2015 - 07:09 PM
Thanks Stiggytoo, I have a strippers, crimpers and a box of various bits and pieces connection-wise but I do definitely need to expand my collection.
#20 bob540
bob540
  • 357 posts
Posted 29 July 2015 - 05:58 PM
Fitted the new spade connector just now and it's running perfectly again, gotta love an easy fix :) My friendly neighbourhood motor factors didn't even charge me for the connector. Thanks for the help lads, It's very much appreciated :)
#21 Austin1987
Austin1987
  • 20 posts
  • Local Club: 998
Posted 31 July 2015 - 08:17 AM
First thing I would check is the engine mounts and steady s, sounds odd but I had a similar thing and fount the engine was moving back and forward too much causing all kinds of jolting and rough running. but in neutral and ticking over the engine sounded fie.
New engine mount bushes and he was back to normal.
