I have fitted a stage one kit to my girlfriends mini.
Its a 1994 Mini 35 1275 carb (originally had a CAT).
When it comes to mot time will the car pass the mot.
We had it on a rolling road and all tuned up to 63bhp. (drives lovely now)
I have had a look at many forum links and the MOT test regulations online and it says you cant test the car on a cat emissions test because it don't have one.
You need to mach the VIN number up to the analyser database to check to see which specs it comes under.
I have looked at the post on here in the injected sub forum and our vin number don't correspond to the ones it could match to, so does that mean it has to be tested under the non CAT test?
I believe my engine code is "D" in the vin number.
Sorry if i haven't made much sense, just want to know if it should pass ok or will i have to refit the CAT for MOT?
