De-Cat And Mot Time 1994 Mini
#16
Posted 02 August 2015 - 10:24 PM
#17
Imo, stick it through the MOT and see what happens.
#18
Posted 02 August 2015 - 10:25 PM
#19
Posted 02 August 2015 - 10:27 PM
Not a fan to be honest.
Well mine has nothing to do with a golf very last real Skoda engine. Has many vw/Audi parts but not on the engine.
Your starting to sound like a Land Rover owner. They deny the existence of BMW engines in their cars. All hand built in the UK my backside. lol.
#20
Edited by ninham, 02 August 2015 - 10:28 PM.
#21
Posted 02 August 2015 - 10:30 PM
Indeed. She will have to ask me nicly to put the exhaust back on with the cat on it
One of the downfalls of buying a later car. Luckily my car was made just before the rules changed, but still limited, at MOT time, to 3.5%.
#22
Posted 02 August 2015 - 10:32 PM
by the way, I do like a lot of the Skoda range. The Octavia VRS is a nice car.
#23
#24
Posted 02 August 2015 - 10:35 PM
I agree, one was following me on the way home. Was dreaming a bit..... Wish I had more money..... Then I thought oh I would if I didn't have the mini project. Lolby the way, I do like a lot of the Skoda range. The Octavia VRS is a nice car.
Nearly bought the mk1 Octavia vrs the 20v but got the little felli instead, with 6k on the clock.
#25
Posted 02 August 2015 - 10:36 PM
Well we will have a whole month to sort things out, which gives me enough time to put the cat back on and tweek the mix a bit. Will be horrible to drive down there.
Don't bother tweaking the mixture if you don't have a co machine. Not worth the hassle. I would send it for a test, and see what happens, or just fit the cat to be safe.
#26
Posted 02 August 2015 - 10:37 PM
Fitting the cat means removing whole exhaust, lcb and all brackets. GrrrrrDon't bother tweaking the mixture if you don't have a co machine. Not worth the hassle. I would send it for a test, and see what happens, or just fit the cat to be safe.Well we will have a whole month to sort things out, which gives me enough time to put the cat back on and tweek the mix a bit. Will be horrible to drive down there.
#27
Posted 02 August 2015 - 10:38 PM
Bought a mk3 astra estate while the mini is off the road for the turbo build. If my r/c car stops draining my wallet!
#28
Posted 02 August 2015 - 10:40 PM
if it had a carburettor from the factory then it gets a non cat test and you CAN remove the cat because it's not needed for the check.
If it came from the factory with fuel injection then it gets a cat test and you CAN NOT remove the cat because it is needed for the check. It doesn't matter if you can pass the test without a cat it still needs one actually fitted to pass.
This counts for UK registered cars.
So the simple rules for cat removal - if your car falls into the emission test that requires a cat test (see above) then you're stuck with keeping it. If not then the cat can go. Unless it's a diesel with a DPF in which case you have to keep it no matter what but there's not many factory diesel classic minis with DPFs fitted
#29
The worst that can happen is it fails. Then just go home and fit the old exhaust.
#30
Posted 02 August 2015 - 10:44 PM
OK so it will pass without the cat as long as it has a good co and ppm. That's all sorted then. Will let her know :).Put simply after the initial BET check is carried out and failed you get the following rules for classic minis...
Could put a modern diesel in a mini. Would be hard to find one that would fit nicely. Great mpg lol
