Wipers And Heater
Posted 10 August 2015 - 07:03 AM
What wires do I need to look for as it seems as there is a loose connection? Don't think anything is loose on the fuse box but yeah.
Thanks for help
Posted 10 August 2015 - 10:10 AM
http://www.theminifo...s-covered-data/
I dont know what year your mini is, but looking at the above post, if you have the 4 fuse fuse box, then both the heater and wipers should be coming from terminals 5/6, i would check the connections here at the fuse box first for any corrosion
Posted 10 August 2015 - 12:29 PM
Year is 86 and have 6 blade fuses, you know what wire colours they will be?
Posted 10 August 2015 - 12:57 PM
Posted 10 August 2015 - 01:36 PM
Fuses seem to be a common place to start looking.
Posted 11 August 2015 - 03:55 PM
BS AU-7 Wiring Colours which identify which circuit is in the FAQs Electrical section as a Sticky
