Centre Clocks Conversion Loom
Posted 10 August 2015 - 08:12 PM
Posted 10 August 2015 - 09:42 PM
First piece of advise - get rid of the choc block they really aren't ideal in an automotive setting, leave them for the lights in your house. The ideal would be either using a proper male/female connector pair or solder and shrinkwrap.
If you have multiple failures it usually points to poor grounding - and that ground pole looks pretty rusty, probably worth giving the it a good clean with a small wire brush and some electrical corrosion inhibitor (ACF50).
Edited by Icey, 10 August 2015 - 09:43 PM.
Posted 10 August 2015 - 10:16 PM
If you search here on TMF the conversion is covered from start to finish
