New Supercharged Engine Won't Start
21 replies to this topic
#1 Udo
Udo
  • 1,670 posts
Posted 11 August 2015 - 11:38 AM
Right bit of background first.Sorry for long winded explaniation although hopefully will answear questions before they get asked
Friends engine that he had built, spec as below:
1293 fresh bore pistons rings etc new bearings
New cam & followers timed in with dti on adjustable cam timing gear
Head work done by either MED or VmAX (i cant remmeber who mate said)
New roller rockers 1:1.5
Vmax Supercharger kit in general but with a slightly different intake to put the carb in top left hand corner of the engine bay
New electronic dizzy with vacumn
HIFF44 carb with spring in it from S/C kit
LCB manifold 1.75" system
New HT leads new resistive plugs etc
Fuel pressure regulator set to 3psi
Basically all new engine!
With another car on jump leads (so battery doesnt go flat) the car will turn over happily and make noises as if it wants to start but just wont catch.
Advancing/retarding the dizzy makes it sound more or less like it wants to catch (we know the dizy timing needs setting up properly once running)
Checks carried out so far
All plugs firing
Plug leads in correct order
Dizzy drive in the correct way
12 volt now going to the coil (mates wiring!)
Fuel is getting to the carb and to the plugs (however leads to problem below)
After cranking for a minute or so and then stopping fuel drips back out of the air filter (K&N type) (carb has been removed and checked nothing blocking anything and no debris in the carb, no wear etc)
Any help as too
A) Why fuel is leaking back out the carb
B) Why she wont fire up
Gratefully received
#2 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 11 August 2015 - 12:35 PM
1. Where is this fuel? do you mean back out of the filter or from a gasket/overflow outlet?
2. Have you tried cleaning the plugs, you may have just flooded them. I've had this stump me before causing her to nearly catch but then not.
#3 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 11 August 2015 - 01:14 PM
If that's happening its obviously overfuelling....if you crank it without choke but with the throttle fully depressed will it catch?
#4 Udo
Udo
  • 1,670 posts
Posted 11 August 2015 - 02:16 PM
 Fuel is out of the filter
Yes cleaning plugs although they are new. Fuel pressure is set to what mate was told to set it to, although yes can turn it down.
#5 Udo
Udo
  • 1,670 posts
Posted 11 August 2015 - 02:18 PM
Not tried it fully open have tried part open, with with out choke etc
As above I will try to turn down the fuel pressure and try again
Edited by Udo, 11 August 2015 - 02:19 PM.
#6 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 11 August 2015 - 02:20 PM
I would turn pressure right down, it should start on whats in float bowl anyway
#7 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 11 August 2015 - 02:23 PM
Are you sure the cam timing is correct?
#8 liirge
liirge
  • 4,097 posts
Doesn't matter if they are new,
Oil in cylinder and fuel will foul the plugs quickly.
#9 liirge
liirge
  • 4,097 posts
Posted 11 August 2015 - 02:24 PM
If you don't think it is over fuelling and you have spark try putting a cap of fresh fuel directly down the carb and try again. If that works you know it either needs more fuel or there is blockage somewhere,.
#10 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 11 August 2015 - 02:35 PM
How old is the fuel as well.
It can loose octane value quickly & high compression engines are fussy.
#11 Udo
Udo
  • 1,670 posts
Posted 11 August 2015 - 02:58 PM
Yes 100% sure its correct
No blockages in the fuel system - have checked already
Good question - mates car so I'm not surre but will get him to get some fresh
Thanks all for help - will turn fuel pressure down, let plugs dry out/clean them anyway, put some fresh fuel in and try again
#12 liirge
liirge
  • 4,097 posts
Posted 11 August 2015 - 02:59 PM
I still suggest you put a bit of fuel down the carb throat and see what happens.
#13 Udo
Udo
  • 1,670 posts
Posted 11 August 2015 - 08:31 PM
Know the fuel is getting from the carb to the head though.
Thinking about it anyway from the car i.e. not frustrated with it I do think its over fuelling and so flooding it.
#14 blackbelt1990
blackbelt1990
  • 2,614 posts
  • Local Club: Minimus Maximus
Posted 11 August 2015 - 08:42 PM
My mate's turbo was doing this recently, flooding the carb out of every hole. Fuel pressure was set too high and it was blowing the float open.
#15 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 11 August 2015 - 10:21 PM
The suck through kits only need standard fuel pressure. I ran a 3 psi facet solid state pump she. I used a carb. I presume your using a SU. Just Checking you haven't blocked the vent pipe for the fuel bowl / chamber?
