New Supercharged Engine Won't Start
21 replies to this topic
#16 Udo
Udo
  • 1,670 posts
Posted 12 August 2015 - 08:59 AM
Yes HIF44
No not blocked the float bowl vent! and checked it is clear
#17 Udo
Udo
  • 1,670 posts
Posted 13 August 2015 - 07:53 AM
Update.
Had another go at mates mini last night
Turned fuel pressure down to what the gauge was aying was 2psi
Removed, cleaned spark plugs
Compression checked, all bang on the same
Plugs replaced
Turned over and again sounding like wanting to start but not quite there, wont catch, then almighty flames out the exhaust!
Fuel again running out of the airfilter
Turned fuel pressure down 1.5psi turned over again and now doesnt even sound like its wanting to fire and fuel still coming out the air filter?
Any more ideas people?
Fuel regulator is new by the way although could still be faulty I suppose?
Not tried new fuel as yet as mate forgot to get some fresh but said its been in the tank 3 weeks.
The fuel coming out the air filter is concerning me
Edited by Udo, 13 August 2015 - 07:53 AM.
#18 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 13 August 2015 - 12:33 PM
If you have fuel and a spark on an engine in good condition it can only be a matter of the spark not happening at the right time (in simple terms)
So cam or ignition timing.
Is there any fuel coming out of the carb overflow?
#19 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 13 August 2015 - 12:36 PM
Cant be the fuel regulator....if you disconnect the fuel supply the engine should still start from whats in the bowl.
Try it if you want to eliminate the regulator (remembering to block the fuel line)
#20 Udo
Udo
  • 1,670 posts
Posted 14 August 2015 - 08:28 AM
No fuel coming out the overflow just out the air filter
I'm going to double treble check timings on it all as agree fuel and spark and it should try and start
#21 Coxie
Coxie
  • 461 posts
Posted 14 August 2015 - 12:13 PM
Could it be the dizzy drive is 180 out?
Edit: I really should read things properly before commenting.
I'll get my coat
Edited by Coxie, 14 August 2015 - 12:16 PM.
#22 Wrgreen
Wrgreen
  • 27 posts
Posted 24 April 2016 - 11:21 AM
Did you ever get it going? Im trying to start mine and having same issue except it qont even catch at all.
