Fuel Gauge
4 replies to this topic
#1 EricaMay
EricaMay
    Starting My Mini Up
  • 3 posts
Posted 11 August 2015 - 12:24 PM
Okay so my fuel gauge doesn't work properly. It works when it's over half a tank, but once it goes under it stops working? I fill my tank up and it works again? Any ideas on what I need to buy/do to fix this?
Thank you 😊
#2 muckute
muckute
    Starting My Mini Up
  • 3 posts
Posted 11 August 2015 - 12:31 PM
Sounds like the resistance wire on the sender is broken, may be able to solder it up or replace the sender
#3 Dzmarc
Dzmarc
  • 250 posts
Posted 11 August 2015 - 01:06 PM
As Muckute has said, check the send, it is more than likely an issue there if it works to start with.
#4 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 11 August 2015 - 02:04 PM
When you get to the point where you want to take it out, make sure you have used the majority of the fuel in the tank. Then undo the locking ring on the tank sender and pull it out.
#5 EricaMay
EricaMay
    Starting My Mini Up
  • 3 posts
Posted 11 August 2015 - 03:05 PM
Thanks 👍
