Sorry its a 1994, So I wouldn't know what it is until a strip it down ?
1330
#31
Posted 19 August 2015 - 01:33 PM
#32
Posted 19 August 2015 - 01:59 PM
Read Cooperman's post again. It's all obvious with out stripping it down.
#33
Posted 19 August 2015 - 02:17 PM
#34
Posted 19 August 2015 - 04:50 PM
Matty,
Couple of suggestions before you start taking engine out and stripping things down:
- keep track of how much oil the engine is currently getting through
- after taking car out for a decent run do a 'dry' compression test on all 4 cylinders
- repeat with 'wet' compression test, using small amount of oil down bores
- is oil pressure good when engine is hot? Coud be worth fitting mechanical 0-100psi gauge for this
All of these will give you an idea of the state of health of your 1275 motor.
#35
Posted 19 August 2015 - 05:01 PM
Matty,
To be fair I check the oil once a week or just over and only have to top it up slightly now and then. Yeah I've got a compression kit, whats the recommended psi for a 1275 ? I might get a oil pressure gauge then. thanks for your help and advice
#36
Posted 20 August 2015 - 04:42 PM
Compression test results will depend on the specification of your motor, best to run the tests and post up the results.
As a guide, if you get less than 150psi then chances are the tester is not working as intended or your engine is needing a rebuild.
