Mmmmm,,,,, I'm not so sure on that info from the MKI forum, Doug.
The MG1100 had a transverse Engine like the Mini and the Carbs were mounted at the same angle as a Mini (30 Degrees) and looking at the pic of the manifold ^ it does look 'flatter' than 300.
The Inline Engines as fitted to the likes of the Sprite and Midget had different angles to a Mini, I think - and don't quote me - these were 10 or 150 ie, considerably 'flatter' than a Mini and those Manifolds don't readily fit on a Mini. They also needed different spacers for the float bowls or if one piece, as you have pointed out, different float bowls, to ensure the fitted angle of the bowl ends up right.
Also, the Vacuum Take Off (plugged on these) coming off at that angle, I have to say, I've not seen anything like that on a transverse engine, not to say they weren't fitted though.
I think they are for an In-line Engine.
Edited by Moke Spider, 20 August 2015 - 09:18 PM.
