Monkey, since the setup you posted pictures of already has the heat shields and the linkages, no modification would be required. The mods would be needed if you were fitting the heat shield kit for a Mini and trying to use the linkages for a Mini. Your setup should already be "correct" as you have a complete turn-key assembly. You will want to look at the float bowls when the manifold is installed to make sure they are as near level as possible and that they do not foul the bulkhead.
Twin Su Info
#16
Posted 21 August 2015 - 11:55 AM
#17
Posted 21 August 2015 - 01:53 PM
No modern exhaust manifold will clear these without modification.
#18
Posted 21 August 2015 - 03:23 PM
Looks like I have found myself a winter project then guys
#19
Posted 21 August 2015 - 04:19 PM
I had never considered the fit of these (or other dual carbs) with an exhaust manifold. I assumed most people fitting dual carbs would fit a header at the same time.
#20
Posted 21 August 2015 - 04:55 PM
#21
Posted 21 August 2015 - 05:09 PM
No, a header isn't really the same as a manifold. A header is typical made of tubular steel (thin wall pipe) bent into shape. Tuned headers typically have a single pipe for each cylinder where each pipe is the same length and the length is optimized for the particular engine type. A manifold is nothing more than a collector that takes the exhaust from all the cylinders and joins them so they can be routed down a single downpipe and to the exhaust. Manifolds are often made of cast iron and as such are larger than headers as far as the space around the carburetors.
In the picture below you will see an A-series manifold that combines intake and exhaust.
In the picture below you will see the original Cooper/S 3-into-1 header.
And finally, the image below is for an LCB type header as you will find in many current catalogs.
Edited by dklawson, 21 August 2015 - 05:09 PM.
#22
Posted 21 August 2015 - 07:54 PM
#23
Posted 21 August 2015 - 08:34 PM
Cheers james
