Hi;
Do I need to Loctite the Screw that holds the Rear Drum in place?? If so what grade / type of Loctite?
Once the Wheels on I guess it ain't going anywhere.
Posted 22 August 2015 - 08:23 PM
Hi;
Posted 22 August 2015 - 08:24 PM
Posted 22 August 2015 - 08:28 PM
You've answered your own question, however I just nip them up.
Thanks - just checking
Posted 22 August 2015 - 08:31 PM
Posted 22 August 2015 - 08:47 PM
I'm with Steve a dab of copper grease
Posted 22 August 2015 - 09:42 PM
Posted 22 August 2015 - 09:51 PM
Posted 22 August 2015 - 10:06 PM
Posted 22 August 2015 - 10:29 PM
Posted 22 August 2015 - 10:46 PM
Posted 22 August 2015 - 10:48 PM
Posted 23 August 2015 - 02:46 AM
Just on that note. Did the early mini's have the thin gasket between drum and flange, like old morrie's and A30's?
Yeap, sure did until later than you might think!
Posted 23 August 2015 - 08:04 AM
Depends if it's been fit correctly in the first place, i.e. used a bit to grease on the mating surface of the flange.
So a smear of Copper Grease between the mating surfaces of the hub and the drum?
Posted 23 August 2015 - 09:37 AM
Posted 23 August 2015 - 03:46 PM
I also never fit those screws. They do nothing and are a right PITA when they get rusted in.
