Sump Plug
Jimmyarm
, Aug 02 2006 09:48 AM
15 replies to this topic
Posted 02 August 2006 - 09:48 AM
Hi All,
Changed my oil the other day and when I went to put the sump plug back in it didnt seem to screw in properly, i.e. it did up finer tight but if you put a socket on it it would just go around and around.
Its staying in place and doesnt leak but is this normal ? Do i need to get the sump plug thread helicoiled ?
PS. handy hint, previously there was a little drip of oil coming from the sump plug, despite the above, with a VERY small amount of Plumbers mate around the washer this has been resolved. I now have a mini without any oil leaks ! (touches wood very quickly).
Posted 02 August 2006 - 10:08 AM
sounds like the thread has gone or maybe its already been heli-coiled and its spinning on the old threads?
needs looking at asap, if you lose your oil while driving its game over for the engine..
Posted 02 August 2006 - 10:16 AM
Bugger ! lol
Good idea about it already being helicoiled, it does feel a bit like it could be that. The thread on the plug is alright.
Bugger ! lol
Posted 02 August 2006 - 10:34 AM
If it's already been helicoiled (properly) the trhead wouldn;t spin.
Sounds just like the threads damaged and needs helicoiled.
Steel thread inserts in alloy actually give you a stronger thread than what was there originally!
Posted 02 August 2006 - 10:41 AM
I've looked for helicoils before but does anywhere do a kit for doing this as it must be a reasonably common problem ?
Posted 02 August 2006 - 10:46 AM
Yes, but the kit is relatively expensive!
Find a Mini specialist with the correct kit, will be a lot cheaper than buying a kit!
Posted 02 August 2006 - 10:48 AM
Good point but where do you get the kit from if I cant find someone local to do it ?
Posted 02 August 2006 - 10:53 AM
A tool store, or one of the bigger mini suppliers might stock them (although minispares don't list on website)
Posted 02 August 2006 - 10:57 AM
LOL , I though you knew a specific place to get them from. I found a few places last time that do kits.
Any idea what the thread size is ?
Posted 02 August 2006 - 11:00 AM
yes, Wilkinsons tool store in Edinburgh
It's UNC, 5/8 rings a bell!
Posted 02 August 2006 - 12:04 PM
Call the folks at MiniSpares and ask them why they don't carry "TOOL08" which is the HeliCoil kit sold by their U.S. partner, MiniMania. Over here, the kit is $50 which I think would be around 25 GBP. That may sound expensive but if you bought the pieces individually... their total cost would be more than the kit.
Posted 02 August 2006 - 03:18 PM
Thanks Doc
Posted 02 August 2006 - 04:51 PM
MS do an alternative plug which I shall be trying soon as mine is stripped also.
http://www.minispare....aspx?pid=32968
Posted 02 August 2006 - 08:34 PM
I wouldn't put Plumbers Mait anywhere near my oil system personally. I don't like adding grinding paste to the sump.
