Full beam flasher problem
Posted 02 August 2006 - 11:59 AM
Posted 02 August 2006 - 12:03 PM
Posted 02 August 2006 - 12:10 PM
I found that to test if you put a flat head screwdriver between them it will allow a good contact, this will tell you if they work or not!
Posted 02 August 2006 - 12:16 PM
how old is ur car? id say theyr dirty
Posted 02 August 2006 - 12:44 PM
Posted 02 August 2006 - 02:35 PM
Posted 02 August 2006 - 02:37 PM
Posted 15 September 2006 - 04:50 PM
also if you take the steering column cowling off you will be able to see the contacts, make sure they are touching when you pull the stalk. if they are then give them a clean and see if that works!
hi could you tell me the best way to clean the contacts as ive tried the screwdriver thingy and they work it just doesnt work without so how do i go about cleaning these thanks Lee
Posted 15 September 2006 - 05:03 PM
Posted 15 September 2006 - 05:09 PM
thanks Lee
Posted 15 September 2006 - 07:27 PM
