PLEASE HELP :(
Posted 03 August 2006 - 07:04 PM
Does anyone know what has gone wrong please help me, i dont understand how an oil change could stop the engine running
PLEASE HELP
Posted 03 August 2006 - 07:35 PM
Since you've been working under the bonnet, check for any wires or vacuum lines you may have bumped. Specifically I'd look at the vacuum hose to the brake servo to see if it is disconnected at either end.
Posted 03 August 2006 - 08:06 PM
yes a lot have people have had problems download firefox and your probs are sortedAs soon as I try and post on this forum... I'm being redirected by some form of Trojan that got on my system (from here) two or three days ago. Is anyone else experiencing this?
Posted 03 August 2006 - 08:13 PM
Posted 03 August 2006 - 08:53 PM
are you out off petrol just check lolA bit off topic.. Any one know what could be wrong all i did was change the oil. i have checked the wires and pipes and cant find anything wrong
Posted 03 August 2006 - 08:58 PM
Posted 03 August 2006 - 09:02 PM
hi its possible but it shouldn't just stop like that the only way to clean it properly is to take the carb of and check and you might want to check your points they might have closed now that's possible they got a mind off there ownnah its got atleast 1/2 a tank i just dont understand what would cause this to happen would a build up of dirt cause this, if so how could i clear it.
Posted 03 August 2006 - 09:03 PM
LOLIt probably wouldn't, will be something obvious....once you spot it! A Homer Simpson 'Doh' kinda moment, or possibly a 'oh, it works fine in the morning, never mind' kinda moment i predict
Posted 03 August 2006 - 09:07 PM
Posted 03 August 2006 - 09:20 PM
go through everything you did in your mind step by step to be sure that you didnt do anything out of the ordinary....i find it helps to physically do this (without actually undoing anything etc) to trace your steps...
otherwise i dont know !
Posted 03 August 2006 - 09:40 PM
The only thing i did wrong was forgot to tighten the oil filter up so i whent to turn the engine on and oil sprayed everywhere but then i tightened it up and that fixed that so dont know.
Posted 03 August 2006 - 10:14 PM
my old mini used to start at the same point every time i must have trained it! but if anyone else tried to start it it would flood or if for some reason i didn't use the same starting technique it would flood.
try leaving it a while then starting it.
Posted 03 August 2006 - 10:18 PM
hi just check that you never pulled the distributor wire out from the loom if you did you wont get a sparkAll i did was run the engine till it was hot, then i drained the oil out, then i changed my automatic oil filter, then i filled it back up.
Edited by ANDY J, 03 August 2006 - 10:18 PM.
Posted 03 August 2006 - 10:22 PM
