I know haha i will have to go and search for some today, are hammerite thinners any good for just the primer?hee hee
using just a regular cellulose primer and toolstation secial white spirits.... which i have since forund is the wrong thing haha!
If the primer is Cellulose, then a standard cellulose thinners is the correct type to use.
It would help if you told us what primer and thinners you have if you could?
Ben
What a mistaka t maka
Cellulose Reacts With Thinners
#16
Posted 13 September 2015 - 08:45 AM
#17
Posted 13 September 2015 - 12:08 PM
#18
Posted 13 September 2015 - 12:56 PM
Hammerite thinners will also react, If using primer use cheap thinners when putting on the paint use best thinners.
please dont give bad advice unless you know for certain.
#19
Posted 13 September 2015 - 02:21 PM
As has been said, 5 litres of standard thinners can be had for around £10.
Might as well get the correct stuff. Do it right, do it once
#20
Posted 13 September 2015 - 02:29 PM
#21
Posted 13 September 2015 - 04:41 PM
#22
Posted 13 September 2015 - 07:18 PM
am i right in thinking that i should use anti bloom thinners for the top coat?
#23
Posted 13 September 2015 - 07:47 PM
It helps if you are spraying in damp conditions but isn't necessary in good weather or in a heated area/booth
#24
Posted 13 September 2015 - 09:44 PM
Sorry Boss !! Was the bit about purchasing from a paint factor bad advice too?
#25
Posted 14 September 2015 - 01:35 PM
I asked the guy in my paint shop why it was such a nasty brown colour and they said that the colour comes from rust inside reusable drums it is stored in.
A painter that was in the shop,at the same time said the same thing.
#26
Posted 14 September 2015 - 04:25 PM
Its because its recycled many times that its a dark colour.
#27
Posted 14 September 2015 - 09:08 PM
Horrible stuff. Only used it once and never again.
Probably explains why it stinks too.
