Hello,
I have a 1982 mini HLE however it doesn't appear to be the original engine.
The car was driving fine a few days ago but as I was driving there was a noise that sounded like a clunk (clunk, clunk, clunk...) which increased with revs. It did seem to disappear in the higher range of revs. I got home turned the car off then restarted it, it started but would not idle right and kept cutting out. I pulled the choke out to keep it going while I tried to investigate. I removed the air filter as it sounded like the carb was blowing back (it was and seemed to be wet with petrol.) I resembled the air filter and left the car for the night. I tried to start the car the next day and it wouldn't start up, it would turn over until the carb would blow back and then nothing. I looked up the issue on a few forums, it appeared the common problem was linked to the coil not working so that has been replaced but no luck. I did manage to get the car started once but it seemed like it was just luck, it was blowing back a hell of a lot and the exhaust was puffing ( not constant.
I have recently changed the condenser, the points, the distributor cap and inline fuel filter.
Does anyone have a possible solution to this? if I need to provide more information please tell me what I need to find out.
Thanks in advance,
Callum
