Also thanks a lot from me as this thread was very useful today as we also fitted the Ignitor and a Flame Thrower coil.
Wire Size
nollyd
, Sep 18 2015 10:56 AM
Best Answer dklawson , 18 September 2015 - 05:53 PM
That is correct. You have effectively bypassed/eliminated the ballast resistive wire and are now supplying 12V to coil (+). The electronic ignition module's red wire will be connected to coil (+) so it gets 12V. The black wire from the module will go to coil (-) and this takes the place of the short white/black wire that used to go between coil (-) and the distributor when points were fitted. If you have a tachometer, its sense wire will still go to coil (-).
Go to the full post
15 replies to this topic
#16
Posted 20 September 2015 - 06:11 PM
