Hi All,
I put brand new Falken 165/65 R12s, on my 89 998, roughly 8 weeks ago. They now resemble racing slicks!! Obviously a suspension issue, to be investigated.
So which tyres do you have and how long do they last?
Posted 21 September 2015 - 05:53 PM
Hi All,
Posted 21 September 2015 - 06:16 PM
So they are not worn even ? tracking camber ? if there worn completly smooth across the tread as its a 998 your not the chap I see in Halfrauds doing burnouuts
Posted 21 September 2015 - 06:27 PM
15k for my 539's and still have 3mm of tread
Posted 21 September 2015 - 07:00 PM
Wear is on the outside, literally the tyre is half and half, so no donuts by me lol.
How do you adjust the camber? I will get the garage to do wheel alignment when they fit the new tyres, just interested.
Posted 21 September 2015 - 07:04 PM
Mine wear on the inside edge like this, running 1.5 negative camber bottom arms, but I think it's more to do with my toe in/toe out, and not just negative camber alone, as this happened pretty quickly and it drives like poop and stevie wonder could see the toe out from the front.
Edited by RossKnight, 21 September 2015 - 07:04 PM.
Posted 21 September 2015 - 07:37 PM
I've done about 8 or 9k on my 539's, they're still very legal.
Posted 21 September 2015 - 07:41 PM
I've noticed my steering has got gradually worse as the tyres have worn away.
What is the correct camber and toe in? I have no doubt the garage will ask, what I want it set to.
Posted 21 September 2015 - 07:46 PM
I've got this
Posted 21 September 2015 - 08:21 PM
Thanks for that RossKnight. Interesting bit at the bottom about rubber cones, I suspect that my rubber cones need replacing as my mini has a raked looked, which might be (pls correct if wrong) putting more downward pressure through the front tyres, which could be causing the camber to be out.....
Posted 25 September 2015 - 09:00 AM
Posted 25 September 2015 - 11:00 AM
4 years and about 10k on my falkens and still look almost new! Will need to get new ones because of age rather than wear I think.
Same, as the sidewalls on mine, the ones oddly not sat in the sun all the time are starting to crack quite badly.
Posted 25 September 2015 - 11:05 AM
I'm sure my Camacs wil outlast my car!!
Posted 25 September 2015 - 03:45 PM
Posted 25 September 2015 - 11:23 PM
Only because you'll end up skidding into a ditch with them!
I like my cars set up loose !! lol
Posted 27 September 2015 - 05:22 PM
My Yoko A008s are 11 years old!!!! and still have loads of tread - obviously don't do enough miles! Really mean to change them as they arent exactly sticky anymore in the wet!
