Radiator Problem
58 replies to this topic
#46 Keith Staley
Keith Staley
  • 83 posts
Posted 20 October 2015 - 01:05 PM
received_10153383411722912_zpsisjxebjl.j
Gentlemen ! Take a look at it for yourselves!
I'll replace the water pump and report back. But I can't thank you all enough for your help !
Yep, that's what I thought it would be, as mine was exactly the same as yours.
It's down to the antifreeze not being changed and the system not being flushed in a long time which causes corrosion build up.
As 1984mini25 says, make sure you fit a good quality bypass hose and ensure you clean out all of the waterways before you build it back up, otherwise you'll have to take it all back off again.
#47 David128
David128
  • 644 posts
Posted 20 October 2015 - 03:49 PM
It looks like lime scale.. Are you in a hard water area?
#48 Chinna
Chinna
  • 28 posts
Posted 20 October 2015 - 06:02 PM
I've only had the car a few weeks. I don't know the history of the car much. Keith says it is old anti freeze
#49 Chinna
Chinna
  • 28 posts
Posted 20 October 2015 - 06:27 PM
#50 Keith Staley
Keith Staley
  • 83 posts
Posted 21 October 2015 - 01:25 PM
At least you've found the problem now which is good news.
Being as we do live in a hard water area, you might want to use distilled water instead of ordinary water but personally I don't bother.
You need to use the blue anti-freeze when you get it built back up, but notice on the bottle that it only has a working life of 2 years so put a note in your diary. Now that you're quite familiar with the cooling system, it really doesn't take much to drain and flush the system and top back up with anti-freeze every two years. People seem to think it lasts forever and ignore it, but as you've found out it deteriorates, causes corrosion and slowly stops doing the job it was intended to do.
Keep us posted on how you get on...and maybe a picture of the now healthy patient with its new silicon hoses fitted
#51 Spider
  • 15,225 posts
Posted 21 October 2015 - 06:44 PM
There certainly was a big blockage. It was in the connector between the radiator bottom hose and the heater hose.
With some reasonable certainty, I can assure you, that will not be the only blockage.
Have the entire cooling system professionally cleaned, you are wasting you time otherwise.
Sorry, I'd actually say found part of the problem.
If the pump and the top hose looks like this, it won't be limited to these two components.
#52 Chinna
Chinna
  • 28 posts
Posted 21 October 2015 - 08:36 PM
Moke Spider
Other than the engine block itself, I've cleaned or renewed everything in the cooling system (I think)
1. Radiator
2. Hoses
3. Cylinder head take off
4. Thermostat
5. Heater matrix
6. Water pump
So what else do you feel, would constitute the entire system ?
(I do understand that it is not a professional job with all the cleaning chemicals)
Edited by Chinna, 21 October 2015 - 08:38 PM.
#53 Chinna
Chinna
  • 28 posts
Posted 21 October 2015 - 08:41 PM
Hi Keith, I have a couple of litres of distilled water. I'll use that. Will also renew the antifreeze every two years :)
I haven't got a torque wrench for the water pump. Should I use one ?
Edited by Chinna, 21 October 2015 - 08:42 PM.
#54 Spider
  • 15,225 posts
Posted 22 October 2015 - 12:07 AM
Moke Spider
1. Radiator
2. Hoses
4. Thermostat
5. Heater matrix
6. Water pump
The Block and Head. They are probably the two main parts that need to be the cleanest.
#55 Keith Staley
Keith Staley
  • 83 posts
Posted 22 October 2015 - 12:24 AM
Technically yes, but I didn't bother
#56 1984mini25
1984mini25
  • 8,787 posts
Posted 22 October 2015 - 11:02 AM
I've never bothered using one. As for the antifreeze the cheap pound store stuff is better than just plain water.
#57 Chinna
Chinna
  • 28 posts
Posted 29 October 2015 - 11:32 PM
Alright ,
Changed the water pump. Didn't use a torque wrench. Fitted new hoses and clips. Fresh antifreeze. Filled the heater matrix through the inlet pipe with funnel. Started the car and bled the system. Drove 10 miles !
The needle sits exactly on the white line. It creeps up a millimeter over the white line and settles back on the line !
I cannot thank you all enough for all your help :)
Please do let me know if you are in Milton Keynes next. Will certainly buy you all a drink :)
Edited by Chinna, 29 October 2015 - 11:34 PM.
#58 Keith Staley
Keith Staley
  • 83 posts
Posted 30 October 2015 - 03:38 AM
That's good news buddy, glad you got it sorted out
#59 Chinna
Chinna
  • 28 posts
Posted 30 October 2015 - 10:14 AM
Thank you Keith. Well, to be honest it was a collective effort :) So, As I mentioned, "We" sorted it out :)
