Opening rear windows
34 replies to this topic
#1 Dave the Rave
Dave the Rave
  • 140 posts
Posted 09 August 2006 - 11:24 AM
I've changed the seals on them before but am sure they still leak slightly. I was thinking of sealing them up!
Just seems like the cr@ppy closing catch doesn't pull the window in enough. Also i've had two catches break on windows before! They're not exactly the strongest. Luckily i managed to pick up a rear window from Southern Mini Days for 3 quid!
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 09 August 2006 - 11:42 AM
mine are rain proof but not hose proof
#3 Flyby
Flyby
  • 184 posts
Posted 09 August 2006 - 12:31 PM
Mine are not too bad unless it rains very hard and then thereis some seepage, but like Bungle says, mine arent hosepipe proof. After washing mine I always open the rear windows to allow any sitting water to drain out and also chammy the sills where the windows sit.
#4 minipixie
minipixie
  • 1,646 posts
  • Local Club: Lincoln TMF and Notts TMF
Posted 09 August 2006 - 12:41 PM
not noticed mine leaking!
#5 ]GoD[Zander
]GoD[Zander
  • 464 posts
  • Local Club: N/A
Posted 09 August 2006 - 12:44 PM
i did get some rust under one of them and that made them leak just check for that and the seals
#6 walks
walks
  • 141 posts
Posted 09 August 2006 - 04:42 PM
i havent noticed mine leaking when ive washed it - they'll probably start to now ive said that though :'(
#7 Dave the Rave
Dave the Rave
  • 140 posts
Posted 09 August 2006 - 04:50 PM
Yeah they don't leak too bad unless it hammers it down but they let in water when i wash it. Water normally sits around the seal and body.
I don't like opening the windows incase another catch breaks off the window!
#8 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 09 August 2006 - 06:15 PM
if you really don't like them just replace them with fixed "city" class. it's mush better if you want to avoid leaks at all costs.
i'm sure there loads of people out there who would want to swap.
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 August 2006 - 04:23 PM
They are a terrible rust trap at best even if they don't leak.
The latch is a bit adjustable, slacken the two screws a bit and slide the base away from the window slightly (really slightly, too much and it just bends things). Play with it a few times and you should get nice tight windows.
#10 minipip
minipip
  • 1,591 posts
  • Local Club: TMF SE
Posted 10 August 2006 - 04:40 PM
lotsa people go opening windows but i dont like them ither tooo much of a saftey risk i think thats y im going sealed soon, just need to get more tinting film to do the new ones :w00t:
#11 mulejones
mulejones
  • 158 posts
  • Local Club: mini diddlers, of retford
Posted 10 August 2006 - 05:13 PM
Yeh mini did leek, but i changed the seal and its now ok..............i think!
#12 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 August 2006 - 06:11 PM
Oh I just have to hear this one.....
#13 minipip
minipip
  • 1,591 posts
Posted 10 August 2006 - 08:34 PM
go on then dan.................what..............what have you go to say to that? >:w00t:
#14 1984mini25
1984mini25
  • 8,784 posts
Posted 10 August 2006 - 09:02 PM
Mine don't leak, stay open and close properly, but they door rust at the bottom were water gets trapped under the seal, just like the doorsteps do.
As once the water has collected, there is no were it can drain or run off to.
#15 Jammy
Jammy
  • 25,397 posts
Posted 10 August 2006 - 09:07 PM
I think Dan was interested to hear why they are a safety risk?
