Front Knocking
Posted 01 October 2015 - 06:59 PM
Has any one got any ideas what this could be because it's driving me insane
If I had any hair I would have pulled it all night
Thanks in advance lee
Posted 01 October 2015 - 07:03 PM
Posted 01 October 2015 - 07:07 PM
Engine or exhaust mounts?
Posted 01 October 2015 - 09:26 PM
engine steady?
Posted 01 October 2015 - 09:44 PM
Really getting annoying now after changing every thing i can think of
Cheers lee
Posted 03 October 2015 - 09:35 PM
Have replaced radiator side mount
The front and bottom emgine steadies were tight with no movent wouls you recomend nee bushes or poss nee dogbones ?
Cheers lee
Posted 03 October 2015 - 10:12 PM
Posted 05 October 2015 - 09:49 PM
I know did the steering rack a few months ago and you are so very right pig of a job drop subframe jack body ang jiggle away but still the knock did not go so have ordered now front and rear dogbone bushes will fit and report but think the knock is deffo from the nsf corner but have raplaced everything i can think of
Any suggestions greatly received
Thanks lee
Posted 06 October 2015 - 12:23 AM
I read your first post about a week ago and I still come back to the same thing I thought then.
I know you've done the steering rack, but a number of things suggest to me it may still be the rack. It is usually one of the knock things that can't be seen and also given that it went away for a while after changing it.
Some racks are better than others and I've heard reports here of new racks lasting considerably less than a year.
Jack up the LH side, grab the wheel at 9 and 3 o'clock, rock it back and forth while looking at the rack if you see the inner moving relative to the outer, than that'll be it.
Still got your old rack? Overhaul it, if you find it is the rack.
Posted 06 October 2015 - 07:58 AM
hi moke
sorry fella it didnt go away after changing the rack its been constant and its driving me insane because i keep replacing parts
and still got the clunk so suppose will keep going have ordered new dogbone bushes so will change them and see what happens
also got lower arm bushes but not fitted yet as poss may buy new bottom arm arm pins
cheers
lee
Posted 06 October 2015 - 08:09 AM
What about shocks? are the rubber inserts good condition. Try going around the block only with them disconnected.
Posted 06 October 2015 - 09:13 AM
hi moke
cheers
lee
Ah, OK got ya.
Thinking cap's still on.
Posted 06 October 2015 - 09:15 AM
Is it your washer bottle hitting the bulkhead? I had a knocking that I couldn't trace and then discovered that an almoast empty plastic bottle can make an unfeasibly loud amount of noise.
Posted 06 October 2015 - 09:30 AM
Hi Guys
thanks for the replies shocks are new KYB gas from minispares
new rack also from them fitted fine also rechecked the u bolts after few weeks all tight
washer bottle is on inner wing and full
keep the suggestions coming
i have replaced the from sub mounts with steel and rubber ones but there seems to be a bit of a gap between the subframe lower front and the lower shell and the mount looks awkwardly
angled could this be it ? if so how would i reduce the gap between sub frame and body shell ?
thanks
lee :)
Posted 06 October 2015 - 10:03 AM
Found the knock at the back
rear cotton real holding the exhaust had sheered replaced and all the back is ok
just the front to sort out now
not too long now before i have a brand new mini with all the parts ive been changing ha
cheers lee
