Coolant For "vehicles Manufactured In ..."
17 replies to this topic
#1 fenghuang
fenghuang
  • 796 posts
Posted 03 October 2015 - 05:09 PM
I was just about to fill the rad with ready mixed coolant. I read the label and it said "suitable for most vehicles manufactured after 1998."
Should I care about this date on a 35yr old design of engine built about 25yrs ago?
#2 CityEPete
CityEPete
  • 3,920 posts
Posted 03 October 2015 - 05:14 PM
Certain versions can't be mixed, the ready mixed is normally the type safe to mix with any existing coolant. I have seen a chart somewhere.....
#3 Carlos W
Carlos W
  • 10,114 posts
Posted 03 October 2015 - 05:18 PM
What colour is it?
#4 CityEPete
CityEPete
  • 3,920 posts
Posted 03 October 2015 - 05:25 PM
http://www.popularme...to/a91/1272436/
probably best to use water for now then get a bottle of the proper old fashioned stuff, it can eat your radiator. The colours are all over the show all over the world, one is safe to mix with either but I cant find which, have you bought OAT? if so I wouldn't use it.
#5 gazza82
gazza82
  • 3,014 posts
  • Local Club: TMF+
Posted 03 October 2015 - 05:26 PM
Needs blue silicate based coolant
#6 Swift_General
Swift_General
  • 871 posts
Posted 03 October 2015 - 05:37 PM
Yes. Modern antifreeze (the pink stuff) uses a different technology. It does not contain silicates which is important in inhibiting corrosion with a cast iron block. It also apparently can attack seals/gaskets although I've no experience with this as I've never had any reason not to use the 'blue stuff'. The ingredients in the blue antifreeze do mean however that you will get scale and other detritus forming hence the reason it needs periodic changing.
#7 fenghuang
fenghuang
  • 796 posts
Posted 03 October 2015 - 05:48 PM
It's pink and was bought for a different car, but never got used.
I'll ger something else, just in case. Presumably it should mention silicate on the label?
#8 CityEPete
CityEPete
  • 3,920 posts
Posted 03 October 2015 - 05:55 PM
http://www.halfords....ntrate-2-litres
It's prestone that can be mixed as it's just the antifreeze rather than anti corrosion that it contains, anything else dont mix it.
#9 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 04 October 2015 - 04:31 PM
as far as we know in work, the red antifreeze should be used with aluminium radiators and the blue on the copper core, though most companies insist on the red stuff whatever the material is as the engine block and pipes etc will look like new. we serviced a generator that had been sat for 10 years with red stuff in it and it was all still perfect and as far as can be told so is the copper core radiator along with all gaskets, seals and rubber pipes. I know I will be using the red stuff in  my mini once its roadworthy :-)
#10 fenghuang
fenghuang
  • 796 posts
Posted 04 October 2015 - 04:52 PM
Interesting.
Any idea what the respective chemistries are?
#11 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 04 October 2015 - 05:04 PM
More information than you may want on antifreeze in the link below.
http://www.machinery...nt-fundamentals
#12 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 04 October 2015 - 05:31 PM
Just for reference, poundland do ready mix glycol based stuff, surprisingly it's a quid
#13 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,857 posts
  • Local Club: man Estate
Posted 04 October 2015 - 05:42 PM
Aye, but how much of it Clive? 500ml? :D
#14 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 04 October 2015 - 06:31 PM
obviously it's one bottle :rolleyes:
#15 fenghuang
fenghuang
  • 796 posts
Posted 04 October 2015 - 06:34 PM
Thanks. Read it, and (no pun intended) the article boils down to this:
Silicates (etc) are used as corrosion inhibitors.
Silicate are used because phosphate containing coolants don't work well with hard water. If you're uaing de-ionised / distiller water, I don't see why that should be an issue.
If you don't change your coolamt often enough, certain compounds in the "anti-freeze" can break down into acids. This in turn can start to corode your engine. (Acid + metal ==> salts + ???)
There isn't any discussion in the article about engibes using components made of different metals : iron, aluminium, copper.
