Coolant For "vehicles Manufactured In ..."
17 replies to this topic
#16 gazza82
gazza82
  • 3,014 posts
  • Local Club: TMF+
Posted 04 October 2015 - 08:21 PM
Don't think the block/head material matters as my Alfa uses blue (I mix 50/50 with de-ionised water) but our later MiTo uses red. Both have alloy engines.
#17 Dusky
Dusky
  • 5,322 posts
Posted 04 October 2015 - 11:48 PM
More information than you may want on antifreeze in the link below.
http://www.machinery...nt-fundamentals
Thanks. Read it, and (no pun intended) the article boils down to this:
Silicates (etc) are used as corrosion inhibitors.
Silicate are used because phosphate containing coolants don't work well with hard water. If you're uaing de-ionised / distiller water, I don't see why that should be an issue.
If you don't change your coolamt often enough, certain compounds in the "anti-freeze" can break down into acids. This in turn can start to corode your engine. (Acid + metal ==> salts + ???)
There isn't any discussion in the article about engibes using components made of different metals : iron, aluminium, copper.
salts +h2 normaly. Wonder where it goes, should blow the rad cap :P
#18 fenghuang
fenghuang
  • 796 posts
Posted 05 October 2015 - 07:14 AM
re metal + acid. Ah yes. It's 30yrs since I did chemistry.
Where does any gas go? The easy route out of the engine is out of the rad overflow.
