mini problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted 09 August 2006 - 08:02 PM
some one must no what the problem is i have sopke to people and they dont no what it could be
can u guys help me out
cheers miniallsor :'( :'( :'( :'( :'(
Posted 09 August 2006 - 08:14 PM
Posted 09 August 2006 - 08:35 PM
i dont understand it
Posted 09 August 2006 - 10:29 PM
sounds like the alternator best way to check is start the car up then disconnect the battery lead while its running if the engine cuts out the alternator is no good ??well when it has been sat for ages it starts up fine
Posted 10 August 2006 - 08:29 AM
How does that work???sounds like the alternator best way to check is start the car up then disconnect the battery lead while its running if the engine cuts out the alternator is no good ??
Go down to your local decent garage or Halfrauds will test a battery or alternator for you. If you have a multimeter you can do it yourself. My money is on your alternator on its way out. Your fan belt does squeal at times does it?
Posted 10 August 2006 - 09:51 AM
it was shot a couple on months ago had a new one put on
Posted 10 August 2006 - 11:28 AM
If it is shot again you need to then find out what is causing electrical components to mess up!
Posted 10 August 2006 - 11:48 AM
Posted 10 August 2006 - 04:00 PM
Actually that's just a pretty good way to fry the control circuit inside your alternator and blow all the electronics and bulbs in your car. The alternator in the Mini is a battery sensing type, it needs to be shown a referance voltage of 12v to know what voltage to produce. Without a referance voltage it could produce any output as the revs increase and start blowing electronic circuitry. Also, this wouldn't stop the engine in any case. The battery only starts the engine, the alternator runs it.
Was your fan belt set too tight when the alternator was changed? There should be 1/2" deflection along the longest run of belt.
Posted 10 August 2006 - 08:58 PM
