I know very little about H carbs. However, they do have a side mounted float bowl like the HS series. As a quick clean, try the following.
Remove the float bowl lid and use spray carb cleaner to wash out the gunk in the bottom of the bowl. Use paper towels to blot up the mess. Do not put the bowl lid back on yet.
Carefully remove the suction chamber from the carb. Be careful not to damage the needle. Use spray carb cleaner on a coarse cloth to remove any gum and varnish on the needle.
With the suction chamber removed, use the spray straw of the carb cleaner to direct several sprays of carb cleaner down the jet. The spray cleaner should come out in the float bowl. Use that soft plastic spray straw to scrub the inside walls jet. Use nothing metal, only the spray straw. Keep doing this until the fluid coming out in the bowl is clean(ish).
Put the carb back together, put oil in its dashpot and try running again.
