Fuel In Vacuum Pipe
Posted 11 October 2015 - 03:50 PM
Posted 11 October 2015 - 03:55 PM
when the engine is stopped , the vacuum is replaced with air / fuel mix from the manifold , at atmospheric pressure
the fuel drops out of the mix & accumulates at the lowest point
there will also be some condensation as well
you could get a device - a chamber with a diaphragm in the centre , which stops the moisture , but maintains a vacuum
but I can't remember the name
some diaphragms are damaged by fuel vapour - vac advance units are prone to this sometimes
similar post for moggies - http://www.mmoc.org....t=22751&start=0
it's called a vapour trap http://www.ebay.co.u...=item464132a6a1
Edited by sledgehammer, 11 October 2015 - 04:08 PM.
Posted 11 October 2015 - 03:57 PM
