Eyelet X2 Spark Plug Hole Engine Lifting Point
engine
15 replies to this topic
#1 ryomini
ryomini
  • 583 posts
Posted 19 October 2015 - 06:49 AM
Yop
again thanks so much to all the contributors on this aaaamazing forum, and to all you different mini owning, driving, racing, modding good people
Here is something I fabbed up and wanted to share if others wanted to do likewise.  This is the current method for lifting old Ford Model T engines.
For the actual lift I think I would use holes 2 and 3 but if there is wisdom out here to do otherwise I am listening.  (Have a project in the can and will post when it all becomes real, for the meantime it's budget tool making)
The recipe was as follows.  2 steel eyelets, 2 used Champion spark plugs (I prefer to use NGK in the car).  I smashed out the electrode and ceramic.  Ground down the thread on the end of the eylet.  Passed it through the plug and welded the bottom.
Care needs to be taken not to foul the threads !!  Then welded the top.  It's dirty because I only have a wire feed 'sans gas', so there's a ton of splatter, but it works out ok.
The eyelets cost me a couple of quid, I expect you could pick up some scrap and do it for peanuts.  Thanks for watching :)
Attached File  CIMG2548.JPG   24.81K   11 downloads
Attached File  CIMG2549.JPG   29.58K   14 downloads
#2 ryomini
ryomini
  • 583 posts
Posted 19 October 2015 - 07:15 AM
Sorry guys I uploaded 2 pics and now everytime I try to upload the remaining pictures it keeps telling me the file size is too big (so dunno what is up)
You can upload up to 884bytes of files (Max. single file size: 884bytes
Edited by ryomini, 19 October 2015 - 07:26 AM.
#3 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 19 October 2015 - 08:08 AM
Best to make a photobucket account and upload photos to that. Then copy and paste the IMG code into your reply and that will show the photos larger
#4 ryomini
ryomini
  • 583 posts
Posted 19 October 2015 - 08:54 AM
Yeah but the first 2 pix uploaded no problem,
now everytime I try to upload I get the same error message
file is only a few ko so there is something amiss somewhere
Edited by ryomini, 19 October 2015 - 08:54 AM.
#5 nicklouse
  • 18,740 posts
Posted 19 October 2015 - 08:55 AM
not really the way i would like to lift 150kg via some threads that are a right pain to fix if things go wrong.
#6 timmy850
timmy850
  • 3,407 posts
  • Local Club: MITG
Posted 19 October 2015 - 09:22 AM
I just used the centre stud with an engine lift bracket off my Mazda. It put the engine at the perfect angle to wiggle it in
#7 Dusky
Dusky
  • 5,322 posts
Posted 19 October 2015 - 09:30 AM
Lifting the engine at the spark plug holes is the last place I d ever lift it..
#8 ryomini
ryomini
  • 583 posts
Posted 19 October 2015 - 09:43 AM
Timmy really nice
lovely garage and lift too, I'll be posting my homemade A frame when the project gets going
thanks for posting
ok here goes from photobucket
#9 Spider
  • 15,222 posts
Posted 19 October 2015 - 09:47 AM
It's actually been done and recommend way since the 60's. Tried and tested.
Marshall & Frazer have this in their book and it's how they lifted Mini Engine on a commercial basis in their own workshop, daily.
#10 Dusky
Dusky
  • 5,322 posts
Posted 19 October 2015 - 10:25 AM
Really? O.o
I would be so scared to try it ;p Always thought the thread was quite 'brittle' ( if that's the right word to use?)
Lean something everyday! :)
#11 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 19 October 2015 - 10:38 AM
The Standard brackets from the factory were off the rocker cover bolts, we used to take them off the Gold seal Engines when fitted
#12 nicklouse
  • 18,740 posts
Posted 19 October 2015 - 10:42 AM
Really? O.o
as was mentioned in the first post it is Common on the Model T but there the plug is vertical in the head. and it is always advised to use rated lifting eyes.
the Mini with the nicly angled spark plug holes. i would just not go there. and those eyes.....
#13 gazza82
gazza82
  • 3,025 posts
  • Local Club: TMF+
Posted 19 October 2015 - 11:51 AM
I'd use the rocker stud mounted ones ... http://www.ebay.co.u...x4AAOSwPYZU7GrM
#14 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 19 October 2015 - 11:53 AM
As mentioned by others above, there is absolutely nothing wrong with using the spark plug holes to lift the engine.  Nothing.
As mentioned by Kernow, the MUCH smaller (5/16") rocker cover studs are often used for lifting.  The spark plugs are much larger.  The load being at an angle is also nothing to be concerned about.  Consider the angle that the rocker cover studs are at when an engine with remote shift is lifted and lowered into the engine bay.
#15 Spider
  • 15,222 posts
Posted 19 October 2015 - 07:00 PM
Really? O.o
If your 'worried' about the strength and weight etc, I usually lift them a similar way to timmy, BUT if there's about 4 threads (yeap 4 only) of the centre stud poking through, I use a flanged nut 'up-side-down' and the flange of the nut stops the bracket slipping off. I think I've been lifting 90% of the engines I've done over the past 15 years this way. The other 10% there haven't been enough threads for. I'll try to remember to snap off a photo later.
Just like the spark plug method, it hangs the engine at just the right angle (if it's rod shift) to get them in and out.
