Love the % numbers. Mine. Never used a lift. The joys of youth. We just lifted them out. And now with the joy of a removable front just drop the front over some wood blocks. But a lift is on my shopping list. But I do remember carrying a power unit down the stone steps from my workshop when I was 20ish. Could have got messy.as was mentioned in the first post it is Common on the Model T but there the plug is vertical in the head. and it is always advised to use rated lifting eyes.Really? O.oLifting the engine at the spark plug holes is the last place I d ever lift it..
It's actually been done and recommend way since the 60's. Tried and tested.
Marshall & Frazer have this in their book and it's how they lifted Mini Engine on a commercial basis in their own workshop, daily.
I would be so scared to try it ;p Always thought the thread was quite 'brittle' ( if that's the right word to use?)
Lean something everyday! :)
the Mini with the nicly angled spark plug holes. i would just not go there. and those eyes.....
If your 'worried' about the strength and weight etc, I usually lift them a similar way to timmy, BUT if there's about 4 threads (yeap 4 only) of the centre stud poking through, I use a flanged nut 'up-side-down' and the flange of the nut stops the bracket slipping off. I think I've been lifting 90% of the engines I've done over the past 15 years this way. The other 10% there haven't been enough threads for. I'll try to remember to snap off a photo later.
Just like the spark plug method, it hangs the engine at just the right angle (if it's rod shift) to get them in and out.
15 replies to this topic
#16
Posted 19 October 2015 - 07:18 PM
Mini Technical Sections →
Problems, Questions and Technical →
Clutch Housing Wear From FlywheelStarted by Jackrabbit18 , 22 Jun 2026 |
Timing Chain And Back Plate ReplacementStarted by homemademini , 19 Jun 2026 |
22G1128 Gearbox With 3-Synchro Straight-Cut Gears?Started by kkonstantinopoulos , 11 Jun 2026 |
Overheating / IdleStarted by crbeasley01 , 09 Jun 2026 |
Hif44 Starter Spindle Seal Fitment IssueStarted by JimmyStinkpickle , 21 May 2026 |
