Just done a good one on a mini I was asked to weld a front end on, that apparently need no other work...
2010, pass with Advisory notice item(s)
Body has slight corrosion (6.1.B.2)
Fail in 2011, with Reason(s) for failure
Offside Front Sub-frame rubber bush deteriorated resulting in excessive movement (2.4.G.2)
Nearside Front Subframe mounting prescribed area is excessively corroded (2.4.A.3)
Offside Front Subframe mounting prescribed area is excessively corroded (2.4.A.3)
Nearside Rear Subframe mounting prescribed area is excessively corroded (2.4.A.3)
Offside Rear Subframe mounting prescribed area is excessively corroded (2.4.A.3)
Subframe mounting prescribed area is inadequately repaired (2.4.A.3)
Offside Front constant velocity joint gaiter split (2.5.C.1a)
Nearside Steering rack gaiter split (2.2.D.2d)
Offside Steering rack gaiter split (2.2.D.2d)
Nearside Front Upper Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.2)
Nearside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Offside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Offside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Nearside Front Upper Sub-frame rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Front Upper Sub-frame rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Nearside Front wheel bearing has slight play (2.5.A.3c)
Offside Front wheel bearing has slight play (2.5.A.3c)
Nearside Front Upper Suspension arm has slight play in a ball joint (2.4.G.2)
Nearside Front Lower Suspension arm has slight play in a ball joint (2.4.G.2)
Nearside Front Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Offside Front Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Offside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Service brake: service brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Offside Rear Parking brake: parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Passed with.... Advisory notice item(s)
and not been on the road since....
Edited by 1984mini25, 21 October 2015 - 01:00 PM.
