Mini Not Starting
19 replies to this topic
#16 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 24 October 2015 - 12:55 AM
Its still worth a try though whats the worse could happen parts get replaced everytime!!!!
Don't take offense.
Changing parts that are not defective clouds and corrupts the troubleshooting process.  Never change more than one thing at a time.  When you change more than one thing at a time and a problem surfaces, you don't know the source of the problem.
In this case, the problem is not the ignition system so changing components there will not get the engine to turn over.  What it will do is cause someone to spend money that they do not need to.
#17 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 24 October 2015 - 11:16 AM
Check for faulty solenoid before buying new: bridge the beefy contacts with a big screwdriver or similar. If the engine still doesn't crank properly (fully charged battery) it's not likely the solenoid at fault.
#18 Blatherskite
Blatherskite
  • 501 posts
Posted 24 October 2015 - 11:17 AM
Don't take offense.
+1
#19 Alpenflitzer
Alpenflitzer
  • 396 posts
  • Local Club: no
Posted 24 October 2015 - 03:53 PM
Only a systematic step by step search and testing will work properly before starting to buy spares..
If you still have a standard battery, did you check the acid content /water ?
What about the earth points? Clean and nor corrosion. Engine earth ok?
Edited by Alpenflitzer, 24 October 2015 - 03:54 PM.
#20 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 24 October 2015 - 04:31 PM
You need to check the battery voltage and charge it if its not 12,65v (100% fully charged) after standing overnight, then charge it fully, once you have confirmed the battery is ok only then do you do a check on the charging system, your looking for the voltage to be across the terminals 14.3v maximum and a minimum of 13.7v, if you cant make those voltages then the alternator is suspect. Do the tests and report back
