When I've Driven My Mini I Come Out Smelling Of Petrol
Posted 24 October 2015 - 12:30 PM
Posted 24 October 2015 - 12:32 PM
Check this is here and make sure it isnt damaged! This will let fuel vapours into the cabin area
Posted 24 October 2015 - 12:39 PM
Yes if carb, check the small breather pipe on the petrol tank inside the boot is secure and not split or missing.....it should run from the top of the tank down the back bulkhead area and out through a hole in the boot floor to fresh air.
If fuel injected there is a more complex filtered vent system.
Also check for leaks and carb float chamber overflow under the bonnet.......this is more dangerous as fuel vapour near hot exhaust manifold is not a good idea!
Also breathing in petrol fumes is not good for your health!
Edited by mab01uk, 24 October 2015 - 12:42 PM.
Posted 24 October 2015 - 12:48 PM
Posted 24 October 2015 - 01:46 PM
I would advise not to drive until leak is found , you can pass out from the fumes & obviously burn as well
as above - float chamber vent , jet tube leak , fuel tank vent , leaking tank / pipe , fuel pump leak are all possibilitys
look under the fuel tank for leaks as well
does the engine bay smell of fuel more than the interior of the car ?
Edited by sledgehammer, 24 October 2015 - 01:48 PM.
Posted 24 October 2015 - 02:25 PM
Well, how lucky is this..?
Had my mini for a year or so now, and have always had a petrol smell - thought it came with the territory.
Reading this, went straight to the garage and voila! Possibly the cause of the smell.? An open pipe sitting on top of the tank!
If this is indeed the problem, where do you suggest the I direct the tube.?
Cheers in advance as this will help the wife complaining of the smell!
Edited by b_sdaddy, 24 October 2015 - 03:46 PM.
Posted 24 October 2015 - 03:05 PM
there should be a hole in the boot floor
Posted 24 October 2015 - 03:45 PM
cheers, will go and have a look. If not then I'll drill one!
Posted 24 October 2015 - 05:01 PM
Look at the fuel pipe. Where that goes through the boot floor is a big grommet with two holes in it. The vent pipe goes through one of them. You won't need to drill another hole.
Rod
Posted 24 October 2015 - 05:13 PM
Cheers.
currently watching the rugby so the mini will have too take a back seat..
Posted 24 October 2015 - 05:49 PM
I changed the tank. Because it was linking in the welded seam!
Can't seem to win
Posted 24 October 2015 - 07:55 PM
Maybe it's a good time to give up smoking!
Edited by Moke Spider, 25 October 2015 - 08:11 AM.
Posted 24 October 2015 - 10:34 PM
Posted 25 October 2015 - 12:47 AM
Mine used to do it with the weber. Also didn't have a breather going to the carb, just ahd a pipe wich vented in a catch tank.
In the end I removed the weber because of it
Posted 25 October 2015 - 02:43 PM
New meaning to Petrol Head
