Center Dash To 3Side?
electrical
3 replies to this topic
#1 TSK95
TSK95
  • 17 posts
Posted 27 October 2015 - 09:50 AM
Hi guys
on my 77 mini (which I'm pretty sure came with the centre dash layout) the previous owner has botched a conversion to the 3 dials on the side, which I like, but the wiring hasn't really been done.. err.. at all? All the wires are everywhere and I don't know what does what.
Has anyone converted one before or does anyone know where I can find the wiring diagrams I need to wire it all back up.
I'm saying this mainly as my battery light doesn't work and thats probably why my battery doesn't charge :(
Help guys?
Cheers!!
#2 johnR
johnR
  • 2,322 posts
Posted 27 October 2015 - 11:23 AM
Have you tried the Haynes manual?
johnR
#3 Icey
Icey
  • 1,584 posts
Posted 27 October 2015 - 12:53 PM
Yep, the Haynes has everything you need really. Dash wiring is pretty simple, it's really just a case of matching colours to functions.
If you're repairing someone's bodge, don't re-bodge it. If you had any plans to use choc-blocks or scotch-locks, forget it now - go buy a soldering iron and some shrinkwrap.
If the bulb has gone or the dicky wiring has disconnected it this is likely true.
Edited by Icey, 27 October 2015 - 01:00 PM.
#4 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 27 October 2015 - 12:58 PM
Give me a shout and I'll make you something to make everything work and for you to patch into your car safely.
I can even supply heathshrink tubes with solder inside so all you do is warm them up - the solder melts and it also makes a watertight seal. Easy especially if you aren't keen on soldering etc.
David
